vtec turns on off
Old Apr 27, 2006 | 06:58 PM
paco4life's Avatar
Default vtec turns on off
I have a little dilema. I have a freshly built ls vtec swap, b18b1 bottom end pr3 head (motor has 2000 miles on it). vtec turns on strong 1st and 2nd gear 3rd and 4th and 5tgh gear vtec turns on and off . the car pulls hard than it drags pulls hard than it drags. its annoying!! anyways i got a type r oil pump, oil pressure is at 20ish psi at idle, and 70 psi full throttle. no check engine lights. oil level is full. what could be causing this?? any suggestions would be greatly appreciated since im tearing into the head this weekend ,im suspecting the oil control orfice under the cams thats messing up oil pressure.
DAN
Old Apr 28, 2006 | 12:46 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: vtec turns on off (paco4life)
Definatly sounds like its not getting enough oil pressure in the head...
Old Apr 28, 2006 | 08:27 PM
postman's Avatar
is it getting the same pressure in all the gears
90ED6LSV
Jul 30, 2013 06:09 PM
tobster
Mar 13, 2011 12:32 PM
4door hobo
Jul 30, 2007 07:53 PM
bigmacks
Aug 11, 2005 12:48 PM
zdr262
Oct 23, 2001 09:29 PM
