sometimes clutch engages way to early when letting off the pedal
my clutch sometimes engages way to early when letting off the pedal.. sometimes it doesnt. Any ideas? Also, when pushing in the clutch sometimes it doesnt feel like its letting go all the way quickly.. sometimes it does.
thanks,
Nick
thanks,
Nick
Varying pedal engagement height is a problem with single diaphragm cerametallic clutch disks as temperatures vary with use.
However, this can be made worse by old clutch fluid (needs to be flushed + bled yearly, just like brake fluid), and a number of other small ****. You hear any squeaks or the like? Do you remember what the clutch form looked like when you put the clutch in - was it worn?
i hook apart the slave cyl. and cleaned it up and bled the clutch again. It seems to be better when I shift, but it seems to activates very early. i dont think it should be this way, but maybe this 6 puck clutch acts this way onces its broken in.
Nick
Nick
AzntaggeR
Aug 8, 2019 09:57 AM
B18Redline
Nov 13, 2007 11:09 AM
