close gear ratio
Old Apr 8, 2002 | 07:00 PM
Dorikamu's Avatar
Default close gear ratio
What can I do to my LS tranny get to closer gear ratio (INSTEAD OF BUYING ANOTHER TYPE R TRANNY.. etc..)
Constructive comment welcome, and I did search already, thanks
Old Apr 8, 2002 | 07:06 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: close gear ratio (chusai)
Open the tranny case, replace all the internals, close case.
You're done.
Old Apr 8, 2002 | 07:09 PM
Dorikamu's Avatar
Default Re: close gear ratio (B18C-EJ1)
what parts do I replace them with?
Old Apr 8, 2002 | 07:17 PM
rainforest's Avatar
change the final drive and gears 2-5.1 is basiclly the same as all the other trannys.
Old Apr 8, 2002 | 07:26 PM
Dorikamu's Avatar
Default Re: close gear ratio (rainforest)
where do I get parts?
Old Apr 8, 2002 | 07:28 PM
B18C-EJ1
Guest
Posts: n/a
Acura dealer.
Old Apr 8, 2002 | 07:44 PM
Dorikamu's Avatar
there is no aftermarket kit?
Old Apr 9, 2002 | 08:33 AM
Dorikamu's Avatar
I suppose changing tranny is recommended?
Old Apr 9, 2002 | 09:18 AM
B18C-EJ1
Guest
Posts: n/a
It's easier.
Old Apr 9, 2002 | 09:19 AM
Katman's Avatar
with all the $$ & work in converting your LS tranny's gears with that of B16A or ITR/CTR gears, you might as well buy a complete used hydro B16A or ITR/CTR transmission.
or you can keep your LS gearing and put a 4.785 final drive in. After doing this though, it won't match ratios of an ITR/CTR/B16A tranny....but at least it will be better than stock LS gearing! ....just a suggestion.
Depends on what you have access to.
Old Apr 9, 2002 | 06:40 PM
Dorikamu's Avatar
Default Re: close gear ratio (Katman)
how much does a final drive run about?
btw, THanks alot for the constructive comment..
[Modified by chusai, 10:40 PM 4/9/2002]
Old Apr 9, 2002 | 09:31 PM
Katman's Avatar
they run about $250 in japan...but over here about $350-500
Knucklehead7
Jan 28, 2008 10:01 AM
Octoman
Oct 16, 2004 02:56 PM
B16X
Apr 13, 2004 01:26 PM
BoOsTeD_eK
Sep 30, 2002 12:27 PM
