ctr lsd?
Old Sep 30, 2002 | 10:54 AM
BoOsTeD_eK's Avatar
Default ctr lsd?
would I be able to put this lsd into my ls tranny?
Old Sep 30, 2002 | 11:05 AM
The_Head's Avatar
Default Re: ctr lsd? (BoOsTeD_eK)
The LS and B16 use the same Quaife LSD's, so maybe...
Old Sep 30, 2002 | 12:27 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: ctr lsd? (xThexHeadx)
Well, I'm not sure about the final drive ratio of the CTR, but I'm guessing it's the same as the ITR.
I put an ITR LSD into my LS tranny, but it wasn't so simple as putting it in and closing up the tranny. The LS tranny has a 4.266 final drive where as the GSR and the ITR have a 4.400 final drive.
First, I thought simply finding a 4.400 final drive ring gear would be good enough, but it wasn't. You have to swap the entire LS countershaft for a 4.400 countershaft from a GSR, ITR, and I believe B16. Plus you also need the final drive ring gear.
Then, you can use the LSD.
I will check the ratios for you now....
EDIT: Okay the CTR is which motor? I'll just list all the B16's
B16A with S4C/S80/Y80/Y21 tranny = 4.400 final drive
B16A1 with Y1 tranny = 4.266 final drive
B16A2/3 with SC4/Y21 tranny = 4.400 final drive
B16B with Y80/S80 tranny = 4.400 final drive
So looks like if the CTR hasthe B16A1 with the Y1 tranny, then it's LSD will work. Otherwise you'll have to do what I did.
Good luck. I hope my info is correct, maybe some other guys can confirm this.
[Modified by shamoo, 4:31 PM 9/30/2002]
Toy Civic
Jun 27, 2014 11:05 AM
Toy Civic
Jan 13, 2007 10:54 PM
b16a1sirhb
Nov 13, 2003 05:00 PM
EG-cellent
Jul 12, 2003 04:28 PM
p1ccoloz
Mar 15, 2003 08:21 PM
