Can I put the 4.785 ITR Final Drive on a LS tranny?
I wanted to know if I could use a 4.785 ITR FD on a LS tranny? Has anyone done it? Anyone know of any links, for reference?
I was hoping to get into the Honda Challenge in a few years or so and they don't aloow modification of the gears, but the FD is open to change. I have seen some inexpensive LS hydro trannys and thought about dropping in a KAAZ and a ITR FD. I don't want to run a gear type LSD since I have heard they don't do well when a wheel gets lifted and then slams back into the ground. I appreciate the help guys
Re: Can I put the 4.785 ITR Final Drive on a LS tranny? (Octoman)
yes the 4.785 OEM HONDA FD can be fitted in a ls tranny.. but you will also require a GSR/ITR Differential (kazz,oem LSD,QUAIFE,CUSCO) since the LS/B16A diffs are of different size and ring gear will not work on a LS/B16A diff
Re: (2FAST4U831)
if you are going to be running in H4 Class with an integra ls then yea it would be worth it... if you are running H1 class then i would go with a type r tranny because you will be in competition with those that are running type r and k series motors...
dan
dan
I am shootin' for H1 since I will be running a hybrid '92 hatch. If you crunch the numbers it wont be to far off from a Type-R tranny and it can give you a little more rpm between gear shifts. I have a b16 right now that I will run just for SCCA for the next year or so, but I will probably be building a LSVTEC for competition in the HC.
Knucklehead7
01-28-2008 10:01 AM
b18bEKcoupe
06-28-2007 11:18 PM
VSM3point5genDC4
10-23-2003 09:11 PM
