Rust Holes
Old Apr 26, 2006 | 06:19 AM
baconcrx's Avatar
Default Rust Holes
I recently bought a 1990 CRX Si, and i have a problem with some rust. the previous owner cut a square out of the d/s dor panel, about 3inchx3inch, should i weld a new piece in or use foam to fill it or just buy a new/used door?
Then for the other rust places, would you all suggest that I sand a bondo the rust areas, or cut them out and fill them in with new pieces of metal?
thanks.
Old Apr 26, 2006 | 11:56 AM
Lamchop0000's Avatar
Default Re: Rust Holes (baconcrx)
weld on sheet metal will work. fine. just kind of difficult if the part has curves and forms.
i dont know about the foam stuff tho. but the best choice would to get new doors.
Old Apr 27, 2006 | 06:32 AM
baconcrx's Avatar
heres the damage
Old Apr 27, 2006 | 06:41 AM
TurboHondaGuy's Avatar
yeah i would dfinetly just cut and weld... if its the rear quarter panels then just buy a new panel for it.. but for the small spots on the drivers side i would definetly just cut and weld... you never just want to bondo over it.. it doesnt fix anything it just gets worse..
Old Apr 30, 2006 | 01:32 PM
baconcrx's Avatar
what do you all suggest about using that stuff that turns the rust into metal.. or whatever it does, compared to sanding down to bare metal and going from there?
Old Apr 30, 2006 | 03:40 PM
dfoxengr's Avatar
you cant turn rust into metal...
Old Apr 30, 2006 | 05:41 PM
B18C1CYA's Avatar
get some of these and replace as much as you can , http://cgi.ebay.com/ebaymotors...ZWD1V
Old May 1, 2006 | 04:23 PM
baconcrx's Avatar
does anyone know how to take off a sunroof?
Old May 1, 2006 | 05:27 PM
Mugencrxsir1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baconcrx &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know how to take off a sunroof?</TD></TR></TABLE> Yes, but it's a pain in the ***, you need to remove the stoppers at the end of the sliding rails, while not scratching the paint. Goodluck, it sucks
Old May 5, 2006 | 05:43 AM
baconcrx's Avatar
Default Re: Rust Holes (Mugencrxsir1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugencrxsir1 &raquo;</TD></TR><TR><TD CLASS="quote"> Yes, but it's a pain in the ***, you need to remove the stoppers at the end of the sliding rails, while not scratching the paint. Goodluck, it sucks </TD></TR></TABLE>
i tried to remove the stoppers, but i couldnt figure out how to do it, got any advice?
DA is best
Paint and Body
Mar 24, 2013 05:18 PM
vteckyle
Jul 29, 2008 10:22 AM
bmxbikes
Paint and Body
12
Mar 2, 2008 07:47 AM
stevescivic
Aug 17, 2007 10:10 PM
90SICRX
14
Apr 27, 2004 11:03 PM
