help fix rust fast..please
Old Mar 22, 2013 | 03:16 PM
DA is best's Avatar
Default help fix rust fast..please
so whats the fastest way to get rid of this rust? grind it to bare metal and use some rust prevention stuff or what?
Old Mar 22, 2013 | 03:19 PM
Fliptard's Avatar
Default Re: help fix rust fast..please
Buy new panels, cut them out and weld the new panels back on.
Old Mar 22, 2013 | 03:50 PM
DA is best's Avatar
nobody makes new panels for DA's
Old Mar 22, 2013 | 06:30 PM
Hidenplanvew's Avatar
cut it out, ruff form a patch panal with some 22gauge sheetmetel then kitty hair bondo then glaze, seal, prime, seal, base and clear
Old Mar 23, 2013 | 11:16 AM
Decatur Racer's Avatar
First pull the rust starter strips outta your wheel wells so it does go further around to other places. You could clean it up the best you can and throw so por15 on it that will prevent it from going further also.
Old Mar 24, 2013 | 05:18 PM
once it starts bubbling the metal in that area is done for.. Only option is cut and replace
vteckyle
Jul 29, 2008 10:22 AM
baconcrx
Welding / Fabrication
May 5, 2006 05:43 AM
90SICRX
14
Apr 27, 2004 11:03 PM
