old school racers - need info on dinosaur NA engine
Old Apr 25, 2006 | 07:29 PM
AutoLab's Avatar
Default old school racers - need info on dinosaur NA engine
I am putting an engine together for a customer who finally got his block back from the "old" RS machine people. He sent it in to be freshened up a year or two ago evidentally during the $hitstorm that went down there. Anyways, long story short, the block is back and is finally assembled.
Some of the old school NA guys may remember the "B22" engines RS did, well this is one of them. Its an LS block with the large deck plate. My question is, does anyone know what head studs to use? From what I can tell so far they arent metric thread anymore. I can get my local parts store to find a timing belt that will work but if you happen to know an application that works well, don't hesitate to let me know. Thanks for your time
-bill
Old Apr 26, 2006 | 11:08 AM
MrParks's Avatar
Default Re: old school racers - need info on dinosaur NA engine (AutoLab)
call golden eale i think they have the answers of the deck plate situation covered, but i think it was a oem belt and a off set water pump pulley
Old Apr 26, 2006 | 11:17 AM
Suprdave's Avatar
Is that Jeremy Lally's (sp) motor? I remember that Car at BOTI like 3-4 years ago with a Monster Deckplate on it.
Old Apr 26, 2006 | 12:09 PM
wade's Avatar
Default Re: old school racers - need info on dinosaur NA engine (Suprdave)
yes it is Lallys engine, its been down forever. Like I said he finally got it back and we're trying to get it ready for the NDRA race in St Louis.
Concerning the belt is wasnt using an offset water pump pulley before.
Old Apr 26, 2006 | 02:48 PM
seen4ever's Avatar
Default Re: old school racers - need info on dinosaur NA engine (wade)
bill could it be 1/2in headstuds? i know geoff had to upgrade to 1/2in headstuds from the std 7/16.
what happened to the original studs? were they just lost in all the engine transitions from shop to shop?
Old Apr 26, 2006 | 05:05 PM
AutoLab's Avatar
Default Re: old school racers - need info on dinosaur NA engine (seen4ever)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seen4ever &raquo;</TD></TR><TR><TD CLASS="quote">
what happened to the original studs? were they just lost in all the engine transitions from shop to shop?</TD></TR></TABLE>
yes along with a lot of other items that he sent back with the engine Ive tried several standard size studs but cannot get a couple of thread pitch options lined out. I'll figure it out just curious if anyone knew anything in the meantime, clock is ticking on this one.
Old Apr 26, 2006 | 10:36 PM
RMF
Guest
Posts: n/a
Those are a special fine thread from ARP .Call Mike at RS he knows the number for them.He also knows what belt too.
Old Apr 27, 2006 | 04:38 PM
Slow00si's Avatar
Default Re: old school racers - need info on dinosaur NA engine (RMF)
i e-mailed them and they have no clue what motor im talking about they tried to say gsr studs work but their about 2" short because they dont make the motor anymore this motor is about 5 years old we have the old belt so we can match it up but nobody has a clue on the studs
Old Apr 27, 2006 | 05:35 PM
ninesecrx's Avatar
Default Re: old school racers - need info on dinosaur NA engine (Slow00si)
On a LS motor the center bolt is longer then the rest. I think its a set you have to order that is basicly all LS center bolts. The stud should be 8 inches long...
Old Apr 29, 2006 | 07:02 AM
Slow00si's Avatar
Default Re: old school racers - need info on dinosaur NA engine (ninesecrx)
that would probably be the correct length but it looks like rs has tapped it for standard threads its no longer a honda thread because we tried threading gsr studs in and they wont start
Old Apr 29, 2006 | 05:19 PM
RMF
Guest
Posts: n/a
I 'm pretty sure I welded that block(If it looks good lol) I'll find out for sure for you .But I think they are 1/2" studs.
Old Apr 30, 2006 | 06:42 AM
Slow00si's Avatar
thanks rmf and yea he had to send it back once to have it rewelded so you might have done it the last time and just let us know what you find out because were trying to get it to the races june 3rd and this is the biggest hold back
Old May 1, 2006 | 04:04 PM
vtecmissle's Avatar
i read a post somewhere dont quote me on this but i think that ford 2.3 turbo bolts do the trick. Call arp and get the thread and length they are 1/2 inch diameter.
Jorsher
Jan 15, 2009 05:42 PM
ZXRider
Apr 24, 2007 08:49 AM
funkified
Dec 7, 2006 11:51 PM
JDM00SI
Feb 24, 2006 03:53 PM
quickersol
Apr 10, 2005 11:05 PM
