cluster swap help..
Old Apr 23, 2006 | 09:34 PM
b_serious's Avatar
Default cluster swap help..
i just got a 00 ex cluster to put into my 98 dx.. but there was only 3 plugs coming out of the harness in the dash.. not 4 like the 00 ex so my tach doesnt work.. whats my solution?
Old Apr 24, 2006 | 01:33 AM
BlueIntegraBoy's Avatar
Default Re: cluster swap help.. (b_serious)
Your cluster might be broken, well at least the tach portion.
Old Apr 24, 2006 | 10:17 PM
b_serious's Avatar
Default Re: cluster swap help.. (BlueIntegraBoy)
when i pulled it, it was working fine.. does the tach have its own socket or is it part of one of the two big ones
Old Apr 24, 2006 | 10:22 PM
bmoua's Avatar
i'm guessing the extra plug is for the rpm...the ex comes with the rpm guage...but the dx doesn't...thats my guess...
Old Apr 24, 2006 | 10:26 PM
sagron69's Avatar
My friend had a dx and we installed my Si cluster in there perfectly. There should be two large blue plugs, which i'm sure you are aware of. There should also be a green one, which i'm sure you're also aware of. Look for a yellow one in the back left hand side behind the tach (remove it to do this) it might be wrapped up in tape. Hope that helps.
Old Apr 24, 2006 | 10:41 PM
The tach wire is integrated into one of the two blue plugs. The wire color is <FONT COLOR="blue">blue</FONT>
Old Apr 24, 2006 | 11:08 PM
b_serious's Avatar
i don't have a green plug, just two big blue and 1 small yellow i looked threw the harness no other plugs
Old Apr 24, 2006 | 11:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b_serious &raquo;</TD></TR><TR><TD CLASS="quote">i don't have a green plug, just two big blue and 1 small yellow i looked threw the harness no other plugs </TD></TR></TABLE>
This is normal for a 5-speed car.
Old Apr 24, 2006 | 11:16 PM
b_serious's Avatar
oh, hmm.. i cut my ecu harness off and converted it to odb1 plugs to run a chipped pr4 ecu.. maybe i got somthing messed up there
could i run the blue wire from the tach to the dizzy?
Old Apr 24, 2006 | 11:21 PM
could i run the blue wire from the tach to the dizzy?</TD></TR></TABLE>
Yes, better yet, I think near the driver side firewall grommet, there's a plug with a blue wire. Tap off that.
Old Apr 24, 2006 | 11:23 PM
b_serious's Avatar
blue wire by itself or in that big socket of wires?
Old Apr 24, 2006 | 11:33 PM
Should be by itself
Old Apr 25, 2006 | 09:06 PM
b_serious's Avatar
is there some type of fuse in the cluster that could have blown or making bad connection i wired the wire to it but didnt work still
Old Apr 26, 2006 | 08:18 PM
b_serious's Avatar
just put the cluster in my other friends dx, and it worked perfectly..
Old Apr 26, 2006 | 08:23 PM
pdiggitydogg's Avatar
Green is actually for cruise control, if my drunken memory serves me right.
If you dont have that, youre A-OK, as far a mechanics speak.
Old Apr 26, 2006 | 09:40 PM
b_serious's Avatar
Default Re: (pdiggitydogg)
so heres and update.. switched the cluster into another dx and it works.. wired it to the blue wire for the tach on the upper side of the enginebay and still didnt work.. what else is there to check?
sanjiyan69
16
Jun 29, 2011 06:52 PM
GriFFIthS
Honda Civic (2001 - 2005)
Jul 7, 2010 07:00 AM
hondanube2010
Jun 30, 2010 05:10 PM
averyvm
Jul 15, 2008 01:21 PM
89dohcEF
Sep 7, 2005 10:44 PM
