WTF? Crank pulley setup? Timing belt guides?
Old Apr 23, 2006 | 03:07 PM
Frozen E's Avatar
H-T White Ops
Default WTF? Crank pulley setup? Timing belt guides?
Ok, I'm putting my engine back together. It's been a year now. I'm stuck on the crank pulley setup.
I have a B16A2 out of a 2000 Si.
I looked on the web at the parts layouts and found this.
That setup shows timing belt guide--timing belt pulley---timing belt guide---crank pulley---crank pulley bolt.
Helms shows the same thing
But here's what I have
If you look at the first pic again, it shows the #'s 12 and 13. Does that mean that there could possibly be two different setups, and happen to have that one?
It's been a year since I took this thing appart, and we were extremely careful in taking everything off and bagging it. Just wanting to make sure. It's sunday and no honda parts departments are open.
Any help would be appreciated.
Old May 21, 2006 | 05:53 PM
mahatma's Avatar
Default Re: WTF? Crank pulley setup? Timing belt guides? (IslandSi)
Yeah you just happen to have the other style.....
Make sure that you reassemble in the correct order like the manual shows (you'd have to switch the pulley & guide around in your pic). Also be sure the curve of the belt guide points away from the timing belt.
Sorry for the late response, I was searching and found this haha
crvglenn
Honda CR-V & Element
Aug 20, 2017 01:44 AM
hmtcrxsir
Dec 22, 2009 10:21 AM
DocSean
Jan 16, 2006 09:20 PM
SOHC_Brian
12
Feb 4, 2005 04:31 AM
sbigblack02
Apr 3, 2004 07:21 AM
