cylinder 1+4 firing to much with COP
Old Apr 22, 2006 | 10:24 AM
salt's Avatar
Default cylinder 1+4 firing to much with COP
Hey I'm having some issues seting up COP on a 30-1000 honda. it is a turbo GSR motor.
I followed these instructions:
http://forum.aempower.com/foru...928.0
It will idle but it misses a lot when it gets over 3000 rpm. I put a timing light on it and cyl 2 + 3 were firing perfectly and looked fine. When I put the timing light on 1 or 4. I could see the timing marks sometimes and sometimes I didn't see any. It was almost like it was firing too much. Also my timing light on 2+3 also read the correct RPM and the RPM on 1 and 4 was way over. Runner 1 +4 on the turbo manifold are also hotter than 2+3
I had a stock distributor and just put a MSD billet one on yesterday hoping that would fix it. It didn't but 2+3 fire so well the crank pulley looks still. it use to look like it was shaking.
i posted my .cal file here:
http://forum.aempower.com/foru...412.0
Old Apr 22, 2006 | 12:43 PM
DaveF's Avatar
Default Re: cylinder 1+4 firing to much with COP (salt)
how do you have it wired ?
Old Apr 22, 2006 | 03:59 PM
salt's Avatar
Default Re: cylinder 1+4 firing to much with COP (Dturbocivic)
its like this with b4 going to EMS coil 1(white) and B3 going to coil 2 (green):
I just retraced all of the wiring and it is correct to the diagram.
Old Apr 22, 2006 | 04:06 PM
DaveF's Avatar
coil # 1 = cyl #1 ?
coil # 2= cyl #2 or #3
coil #3 = cyl #3 or #4
coil #4 =cyl #3 or #2 ??
if you have the coil # match the cyl, you drain the cdi box 2 times in a row, where as if you had the coil # match firing order you would alternate between capacitors.
not sure if that might have something to do with it ???
Old Apr 22, 2006 | 04:42 PM
salt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">coil # 1 = cyl #1 ?
Coil driver one fires 1+4 which are wired in series. coil driver two fires 2 + 3 which are wired in a series. This should alternate 1 2 1 2. Am I missing something ?
The dip switches on the C2DI box are down up down.
Old Apr 23, 2006 | 07:03 PM
salt's Avatar
Does anyone have a calibration with an AEM with a C2DI working ? If you could post it or send it that would help a lot.
Old Apr 27, 2006 | 06:20 PM
salt's Avatar
Last call for help before you see my C2di in the classifieds. If you have a C2DI or MSD dis2 or dis 4 running on the AEM help me out. I will make a detailed post on the problem so that other don't have the same problem.
Old Apr 27, 2006 | 06:23 PM
adictionbass's Avatar
ill take the c2di box
Old Apr 27, 2006 | 06:25 PM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salt &raquo;</TD></TR><TR><TD CLASS="quote">
yea, i belive on the aem cdi's capaciter # 1, fires coils 1&3. capacitor #2 fires coils #2&4..
now you are going 1,1,2,2,1,1,2,2.......etc
draining the box 2 times in a row.
Old Apr 27, 2006 | 06:27 PM
DaveF's Avatar
put your coil #1 in cyl # 1
coil #2 in cyl #3
coil #3 in cyl #4
coil #4 in cyl #2
Old Mar 8, 2007 | 06:22 AM
Finland's Avatar
Default Re: cylinder 1+4 firing to much with COP (dturbocivic)
hate to bring back a dead thread, but did this work?
mortificationrock
Sep 17, 2009 10:38 AM
bopbop93030
Jun 24, 2008 03:20 PM
Dark_Helmet
Jan 12, 2005 05:51 AM
david90
Nov 18, 2003 10:09 AM
Accord94DX
Dec 1, 2002 12:59 AM
