my "maintenance needed" thing faded from green to red??
Old Apr 21, 2006 | 08:31 PM
mikey-ej7's Avatar
Default my "maintenance needed" thing faded from green to red??
its not a light, but a paper thing that rolls? it changed colours
my car runs fine, i've had it since oct, i've changed the oil, no other lights have came on.. anyone know how i can reset this thing? or how i can check it. it' a 99 coupe
Old Apr 21, 2006 | 08:33 PM
BlueIntegraBoy's Avatar
Default Re: my "maintenance needed" thing faded from green to red?? (mikey-ej7)
Stick a screwdriver or key in the slot next to the square indicator
-JSpecEk*9-'s Avatar
its probaly a maintance time again. check the oil, spark plugs
Old Apr 21, 2006 | 09:28 PM
posite's Avatar
just stick a key in the slot by the light or somewhere near it.. (dont remember) to reset it to green. if u keep your car fairly maintained you wont have to worry about half the stuff it recommends to check. however timing belt, water pump, etc.. are highly recommended at certain mile intervals so make sure to look it up.
Old Apr 21, 2006 | 10:36 PM
Syndacate's Avatar
Default Re: (posite)
ya, water pump and tb should be changed every 90k
Old Apr 22, 2006 | 01:34 AM
mikey-ej7's Avatar
Default Re: (Syndacate)
ok I get it, it's like a timer of sorts? and I see it has teeth like gear where I would "rewind" it, thanks guys. I'll be sure to do all the maintnece on it
Old Jun 22, 2006 | 09:54 AM
odieonmybum's Avatar
It comes on when you need to rotate your tires, about every two oil changes.
Old Jun 22, 2006 | 10:02 AM
EeeJayEight's Avatar
Default Re: my "maintenance needed" thing faded from green to red?? (WhiteSleeper)
it is set at pre determined intervals that were set by the manufacturer to help remind the owner that it is time to be service..
there is a little slot next to it on the cluster.. stick your key in and its magically green again... it will soon enough rotate back to red...
JDM_SOHC
10
Sep 7, 2011 06:44 AM
diewnaylomoah
10
May 4, 2007 01:05 PM
illi Adik
Oct 24, 2002 11:39 PM
