Smashed SMSP, fixable?
Old Apr 21, 2006 | 06:43 PM
BlueR's Avatar
Default Smashed SMSP, fixable?
can this be fixed? i'd hate to send this awesome header to an early retirement
Old Apr 21, 2006 | 07:24 PM
tony1's Avatar
Default Re: Smashed SMSP, fixable? (BlueR)
That could easily be fixed, and it's really not that bad as it is, probably won't affect power much at all, if any.
Old Apr 21, 2006 | 07:39 PM
SMSP's Avatar
That is an easy fix, but like Tony said, I doubt you'll lose any power. Some guys local here have a 5 year old header of mine that makes yours look brand new that still beat out some of the new "cutting edge" designs out there.
Old Apr 21, 2006 | 08:14 PM
SQ is the SQUAD's Avatar
id rock it like that
Old Apr 21, 2006 | 11:24 PM
.Thomas's Avatar
Default Re: (SQ is the SQUAD)
id say its fine, better the header then the pan
Old Apr 22, 2006 | 10:30 AM
ManBearPig4silly's Avatar
Easy fix but it's not really worth it unless it's cracked and leaking.
Old Apr 22, 2006 | 03:36 PM
mrbsponge's Avatar
take it to a body shop, and they can use a "stud welder" and they can then put a dent puller on it and ****** it out. it may need a little heat to do tho
Old Apr 23, 2006 | 05:48 AM
George Knighton's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">can this be fixed? i'd hate to send this awesome header to an early retirement </TD></TR></TABLE>
Honestly, I don't think I'd worry about it too much.
With some of his early designs, you're in a bit of Dutch if you straddle a gater or go off in an uncontrolled way: http://is.rely.net/1-92-20925-...g.jpg
Caution: That's a big picture. You'll have to scroll to see what I mean, but you can clearly see that under the compression of a high-G turn, you will get a little close to the ground.
Old Apr 23, 2006 | 09:55 PM
Eddiebx's Avatar
Default Re: (flatblkCR-X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flatblkCR-X &raquo;</TD></TR><TR><TD CLASS="quote">id say its fine, better the header then the pan</TD></TR></TABLE>
dunno about you but i rather dent a 100dollar oil pan then a 1000dollar header,
Old Apr 24, 2006 | 09:48 AM
HiProfile's Avatar
I'm assuming those flanges allow for the collector to be pulled off the runners.
If so, you could even do this yourself. Got to autozone, rent the pipe expander, stick it in each pipe, and go to town. The one they have is made for popping out the dents caused by the cheap u-bolt clamps, so it should work more or less for that. You might have to diy-anneal it, since I'd guess the heat cycles and vibrations would have hardened the metal a bit.
Otherwise, I wouldn't bother. That type of 4-2-1 has so much volume, it shouldn't do much. Only fix it if you take to to shows that require you to stick mirrors under the car
Old May 13, 2006 | 04:37 PM
EJ1enkeiRSE's Avatar
Default Re: Smashed SMSP, fixable? (HiProfile)
nope not easily fixable at all...sell it to me haha
Old May 13, 2006 | 06:07 PM
jdm monkey's Avatar
Default Re: Smashed SMSP, fixable? (EJ1enkeiRSE)
use a pipe expander to make it go back to its original shape
Old May 13, 2006 | 08:05 PM
B18C1CYA's Avatar
yes it is fixable , cap off the ends of the pipe and fill it with compressed air to about 45 psi , and heat the dents with a torch , and watch them just slowly pop out, this method is used on dirt bike expansion chambers to remove dents
Old May 14, 2006 | 07:25 AM
AspectIndustries's Avatar
Default Re: Smashed SMSP, fixable? (B18C1CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA &raquo;</TD></TR><TR><TD CLASS="quote">yes it is fixable , cap off the ends of the pipe and fill it with compressed air to about 45 psi , and heat the dents with a torch , and watch them just slowly pop out, this method is used on dirt bike expansion chambers to remove dents </TD></TR></TABLE>
Very Interesting, I will try this on my old DC headers.
Old May 14, 2006 | 07:48 AM
RPRacing's Avatar
Default Re: Smashed SMSP, fixable? (SMSP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP &raquo;</TD></TR><TR><TD CLASS="quote">That is an easy fix, but like Tony said, I doubt you'll lose any power. Some guys local here have a 5 year old header of mine that makes yours look brand new that still beat out some of the new "cutting edge" designs out there.</TD></TR></TABLE>
yup, that header made 270whp+ on Matt Kennedy's old Motor. Dented and all. right now however, i had some downtime so Dave is fixing it for me cuz Im **** about that stuff. (and my motor makes no power, not due to the header though )
Old May 14, 2006 | 10:21 AM
743power's Avatar
Default Re: (Eddiebx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">
dunno about you but i rather dent a 100dollar oil pan then a 1000dollar header, </TD></TR></TABLE>
that 100 oil pan could turn into a 5k motor when it is dented into the pickup starving the motor of oil.
Old May 14, 2006 | 10:38 AM
.Thomas's Avatar
Default Re: (743power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 743power &raquo;</TD></TR><TR><TD CLASS="quote">that 100 oil pan could turn into a 5k motor when it is dented into the pickup starving the motor of oil.</TD></TR></TABLE>
exactley
Old May 14, 2006 | 12:36 PM
john breezy's Avatar
ouch...that sucks but i dont think its to much to work about
looks like an easy fix
Old May 24, 2006 | 07:29 PM
rodimus's Avatar
Default Re: (john breezy)
that header is worthless you n00bz.
i'll buy it off you
Old May 26, 2006 | 07:44 AM
.RJ's Avatar
.RJ
My header was way worse off and Dave fixed it up for me
Rinsta
Jun 24, 2009 01:48 PM
hgem1si
26
Feb 8, 2008 01:35 PM
pearl
Feb 12, 2007 02:38 PM
nObOdy65
Oct 5, 2005 10:19 AM
92civic_si
Nov 23, 2004 12:55 PM
