Pulsing lights
Old Apr 21, 2006 | 04:45 PM
doublejz's Avatar
Default Pulsing lights
Ok well 2 weeks ago my lights started pulsing and my idle is a little goofy. So I have been doing the normal stuff trying to fix it. I cleaned the grounds made sure they were tight, got a new battery, had my alternator tested at 2 different places = same results its ok. However, if I unhook my alternator well the positive cable, my idle goes back to normal and the pulsing lights stop. I thought maybe the ECU was screwing **** up since 92-95 civics have external regulators for alternators but that didnt work either. So I just ran all new wires battery wire, starter wires and ran the alternator straight to the battery but its still doing the same thing. Any ideas???????
Old Apr 22, 2006 | 06:57 AM
doublejz's Avatar
Default Re: Pulsing lights (doublejz)
bump
Old Apr 22, 2006 | 09:49 AM
Relic1's Avatar
92-95 alternators have internal regulators. the ECU has control of the field but it's only adjusted based on engine RPM and load.
check for wiring problems, especially in the alternator wires.
Old Apr 22, 2006 | 11:15 AM
doublejz's Avatar
Default Re: (Relic1)
oh yea i have a jdm b16 in there if that makes a difference... using a p28 chipped ecu and the original harness for the car.
Now that I think about it, are the 92-95 ex alternators the same as the del sols?
Old Apr 22, 2006 | 05:55 PM
Relic1's Avatar
pretty much any honda alternator from 88-00 will work fine with a P28. Possibly more but those are the ones I know for sure.
stopspazinout
May 31, 2011 07:21 AM
hackjobcrx
Mar 25, 2011 02:36 PM
Boosted EJ2
Feb 6, 2011 11:43 AM
JasonYo
Sep 1, 2010 10:42 PM
whitehf
May 10, 2007 08:40 PM
