after to auto to manual cant start .. errr ..
Old Apr 21, 2006 | 04:32 PM
haveaniceday's Avatar
Default after to auto to manual cant start .. errr ..
well ive wired the 2 thick blk wires together with the blk/blue and a black wire ..i put those four together .. i followed luserkids write up but with the 2 thick blacks and the blk/blue connected i couldnt pull the key out so i put the black on there and it came out .. the reverse lights are not wired .. so the situation is.. the accesories come on but when i turn over like im gonna start they get dim .. i know the ground for the tranny is on i just put it on .. so im kinda stumped right now.. .. i did search but didnt find what i was looking for ..
and the starter makes no noise .. .. also to add everything is tightened down .. battery? ..
it starts now but a new problem doesnt go in gear .. i guess ill bleed the line again and if nothing happens.. i installed the clutch backwards
Modified by haveaniceday at 6:22 PM 4/21/2006
Modified by haveaniceday at 7:50 PM 4/21/2006
Old Apr 21, 2006 | 06:11 PM
hatchi's Avatar
Default Re: after to auto to manual cant start .. errr .. (haveaniceday)
check the wire that goes to the starter
Old Apr 21, 2006 | 06:19 PM
95DxSi-R2
Guest
Posts: n/a
did u jumper the two 12 gauge wires where the prndl switch was. i believe it is black/red, black/yellow
to get the key out of the ignition, unplug the connector underneath the ignition housing (have to remove column covers
Old Apr 21, 2006 | 06:42 PM
Default Re: after to auto to manual cant start .. errr .. (95DxSi-R2)
the slave cylinder pushes the release fork so i guess the clutch could/might be backwards .. any answers?
Robert_West01
Jun 19, 2019 12:53 PM
thexbrothers
Oct 12, 2013 11:49 AM
HondaIsBueno
10
Apr 14, 2008 08:14 PM
philosofy1
Jul 18, 2005 08:37 PM
wu tang
Mar 15, 2005 05:52 PM
