Which size T3/T4 turbo for B18B, 18 psi, around 320-375 HP?
What size T3/T4 turbo should I get for my built B18B? I want to make at least 320 HP and I would like to start boosting around 3000-3500 RPM and see full boost around 6000-7000 RPM. I was looking at a .63 trim, but I think the lag will be a good bit more than what I want. I would really like to know from people with experience with each size turbo. Thanks in advance.
t3/t04e 57trim made 350+ @15psi for me........and it could have made closer to 400whp if i had a real exhaust system........
I would recommend these specs:
T3/T04 "E" compressor housing turbo
57 - 60 trim compressor wheel
.63 exhaust housing
Stage 3 or 5 exhaust wheel
3" downpipe
3" test pipe
3" exhaust
This turbo and exhaust system configuation will give you quick spool up and will flow enough air to support your HP requirements. If you can get a 60 or 61 trim compressor wheel, you will be able to make more HP at lower boost levels.
.63 exhaust housing
3" downpipe
3" test pipe
3" exhaust
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streamline1 »</TD></TR><TR><TD CLASS="quote">I would recommend these specs:
.63 exhaust housing
3" downpipe
3" test pipe
3" exhaust
This turbo and exhaust system configuation will give you quick spool up and will flow enough air to support your HP requirements. If you can get a 60 or 61 trim compressor wheel, you will be able to make more HP at lower boost levels.</TD></TR></TABLE>
.63 exhaust housing
3" downpipe
3" test pipe
3" exhaust
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhatBoy5015 »</TD></TR><TR><TD CLASS="quote">Ok cool. I am planning on keeping A/C and P/S. Will a 3" DP affect these at all?</TD></TR></TABLE>
depends on the manifold
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat »</TD></TR><TR><TD CLASS="quote">depends on the manifold</TD></TR></TABLE>
I'm getting a Revhard cast manifold.
57 trim, very good turbo for what you want.
with the 3" exhaust system you should see full boost before 5k rpms
57 trim .63 is a good choice as others have stated. you may just need to have someone fab you up a 3" for that, it will need to be tight radius but it is possible.
Check out http://www.spoolinperformance.com they have their quick4ac mani. and 3in. d/p thats a/c friendly
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhatBoy5015 »</TD></TR><TR><TD CLASS="quote">How much of a difference in spool time and power is it between a 2.5" and 3" Downpipe?</TD></TR></TABLE>
Anybody?
Anybody?
prob not much of a difference in 3" DP compared to 2.5" . I have a 3" DP and exhaust but at one point it has a dent making it almost 2.5" , I still made really good power on the b18b.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhatBoy5015 »</TD></TR><TR><TD CLASS="quote">Could I get a RevHard manifold and then buy the Downpipe from Spoolin Performance? Would the dimensions still be the same? Cause I just can't see spending $650 on the manifold.</TD></TR></TABLE>
sorry to say but u gotta pay to play
all my setup was custom. but worth it, made real good power at a conservative tune and still there is room to grow
LSTDB8
Sep 1, 2005 04:23 AM
