lights dime down
Old Apr 21, 2006 | 06:51 AM
existanzcivicb20's Avatar
Default lights dime down
ok I have a 1997 ek hatch with a b20 my problem is that when in stoped a red light my lights dime down but when I start going at
about 3500 rpm the light go back to normal and you can feel a extra push in power can any one help me with my problem or just
steer me in the rit direction thanks
Old Apr 21, 2006 | 06:54 AM
miahmouse's Avatar
Default Re: lights dime down (existanzcivicb20)
Check all your grounds and alternator connections...
check output of alternator at low rpm...
if all grounds and connections are good then the alternator/regulator is on it's way out...
Old Apr 21, 2006 | 06:58 AM
Default Re: lights dime down (miahmouse)
my guy works at napa auto parts and he checked the alternator came out good and I have hks ground kit but I havent installed it
Old Apr 21, 2006 | 07:05 AM
miahmouse's Avatar
I'd check the grounds then, there really isn't anything else in the system that will cause a voltage drop. if a fuse is blown, it's blown = no voltage. If a relay is busted, it's busted = no voltage.
Lights dimming + loss of power points to a drop in voltage or bad connection.
Old Apr 21, 2006 | 08:32 AM
thanks a lot chief ill check them tonight ill let u no how it turns out
Old Apr 21, 2006 | 10:21 AM
Relic1's Avatar
a little dimming is normal, but a lot is not.
a battery on its way out will do this also.
Something to think about, the NAPA test on alternators simply tests if it produces power. Not if it produces full power. You could have one or two diodes bad in the alternator and it would still look good to NAPA techs yet not produce as much power as it should.
Old Apr 21, 2006 | 11:12 AM
Default Re: (Relic1)
I just changed the batery but im going to change the ground wires and alternator I think it will solve my problem thanks
dakota1820
Honda Civic (2001 - 2005)
Apr 14, 2013 10:19 PM
xTomei
25
Jul 12, 2010 05:57 PM
le0ftw
Jun 9, 2009 09:33 PM
weavertime1
13
Jan 26, 2009 07:14 PM
haroldthefly91crx
Dec 23, 2006 01:05 PM
