skunk2 dual bend shifter owners
Old Apr 20, 2006 | 10:36 PM
vc's Avatar
vc
Default skunk2 dual bend shifter owners
I put my skunk2 dual bend shifter in today, and its HELLA stiff. the throws are very short but its VERY stiff. Does anybody have a picture of how it's connected with the linkage?
Old Apr 20, 2006 | 10:55 PM
dinko's Avatar
Default Re: skunk2 dual bend shifter owners (vc)
its supposed to be that way homieee
Old Apr 20, 2006 | 11:53 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: skunk2 dual bend shifter owners (dinko)
Did you overtighten it?
Old Apr 21, 2006 | 05:48 AM
Muckman's Avatar
Moderator in Chief
You over tightened the bolt that connects the linkage to the lever.
Old Apr 21, 2006 | 07:53 AM
vc's Avatar
vc
Default Re: skunk2 dual bend shifter owners (Muckman)
I'm scared if I loosen it a bit, the nut will fall off. Did you guys use all of the hardware that came with the shifter?
Screw - Washer | linkage | Shifter - Washer - Spacer | linkage | Nut
Old Apr 21, 2006 | 08:41 AM
Muckman's Avatar
Moderator in Chief
Yup Ive had mine come loose twice but it starts to rattle before it falls off.
I would put the washer on the nut side since thats what will loosen.
I try to make mine as tight as I can without the shifter being too stiff. Throw some grease in there too.
Old Apr 21, 2006 | 08:53 AM
vc's Avatar
vc
could someone post a picture of how yours is setup, I'll try to get a picture of mine later today.
Old Apr 21, 2006 | 08:55 AM
Muckman's Avatar
Moderator in Chief
I took a picture for you bro.
Looks like I have washers on both ends.
Old Apr 21, 2006 | 09:41 AM
vc's Avatar
vc
It's smooth, short, and comfy right? Mine is HELLA stiff and non comfy at all.
Old Apr 21, 2006 | 09:55 AM
Muckman's Avatar
Moderator in Chief
Yes its perfect. Very notchy and direct. Make it really loose and give it a try. Note the difference in stiffness. Then find a place in the middle by tighting the nut and testing the shifter. And like I said use some grease on the friction points.
kulo
Transmission & Drivetrain
Dec 16, 2008 06:12 PM
Bump
Dec 25, 2006 11:32 PM
Mr. Giggles
Aug 12, 2006 05:49 PM
wowowee
16
Jul 6, 2005 11:13 AM
carsaregood
13
Dec 3, 2002 08:41 PM
