Fan wont turn on.
Old Apr 20, 2006 | 07:13 PM
The Destroyer's Avatar
Default Fan wont turn on.
I recently just fixed a headgasket, and the fan wont kick over for ****.
I jumped the fan switch plug and it works, which leads me to believe the relay/fuse is good not to mention the fan motor. The thermostat is new and works to my knowledge (lower rad hose gets hot). I swapped out thermostat switches from a spare motor and that didnt work (not sure if the other switch was good to begin with).
Right now im just stumped, and any help or insight would be greatly appreciated.
Old Apr 20, 2006 | 07:16 PM
FalkenSiR's Avatar
Default Re: Fan wont turn on. (Vtaaak y0)
Does it overheat? Have you tried another relay?
Old Apr 20, 2006 | 07:30 PM
Default Re: Fan wont turn on. (fast88std)
Doesnt overheat. I havent checked the relays/fuses just because it worked when i jumped it.
The only one I know to look for is the fan motor relay I think it is, and it is behind the passenger headlight. Other than that, I do not know which fuse or other relays to check.
Old Apr 20, 2006 | 07:43 PM
FalkenSiR's Avatar
Check this out https://honda-tech.com/zerothread?id=1599625 Look at what fuses to check for. Thread is 2 lines up.
Old Apr 20, 2006 | 07:47 PM
I take it I check for the coolant fan.
I do not have the sticker on the cover, it is in my glove compartment, and yes i am very lazy.
Old Apr 20, 2006 | 08:29 PM
verycleanhatch's Avatar
Did you bleed the coolant for air bubblers?
Old Apr 21, 2006 | 05:13 AM
Default Re: Fan wont turn on. (verycleanhatch)
Yes all air bubblers are out.
Im going to check the fuses and relays today.
Old Apr 21, 2006 | 06:52 AM
miahmouse's Avatar
if you jumped the thermal switch (on/near the thermostat) and the fan came on then the thermal switch is bad...
Old Apr 21, 2006 | 10:38 AM
Default Re: Fan wont turn on. (miahmouse)
Anyone know where to get a thermo switch?
i have 2 and I guess they are both bad.
Old Apr 21, 2006 | 11:53 AM
michaeg6's Avatar
its either the thermostat ( use a jumper wire), fuse located in the engine bay. or the relay beside the fuse( normally, you just have to shake the relay, often times its just stucked up)
Old Apr 21, 2006 | 01:19 PM
Default Re: (michaeg6)
Got it running. I let it idle for god knows how long, turned it off swapped out the 7.5 amp in cab fuse, and made sure all engine fuses/relays were in tight. Then let it idle for another long amount of time and sure enough she kicked over. Monitored it for the next 30 mins let it go on and off about 4-5 more times and made sure everything was good (overflow, rad fluid).
Thanks for the help fellas.
808zrk
Sep 2, 2012 08:47 PM
clowery89
Jun 23, 2010 06:17 AM
Ldo
Dec 8, 2008 11:43 AM
THE GAME IS THICK
Feb 12, 2004 04:08 PM
turbo*s2k
Oct 28, 2003 08:05 AM
