cooling fan not coming on!
Old Oct 27, 2003 | 01:59 PM
turbo*s2k's Avatar
Default cooling fan not coming on!
My cooling fan is NOT turning on. Just wondering what I can do to check the thermostat switch/sensor is working. I checked the fan, and it's plugged in. I checked the plug on the harness, and if I jump it the fan turns on. Right now I set it up to turn on with a toggle switch I have in the car. (Old NOS switch.) But before I buy a new thermostat switch. I want to make sure that's it... I may have damaged it a few days ago when some hot coolant spilled on it. Could that be it?
Thanks for the help!
Old Oct 27, 2003 | 02:03 PM
b20turbojason's Avatar
Default Re: cooling fan not coming on! (TurboChrgd_Civic)
there should be a fan relay that might be bad.
Old Oct 27, 2003 | 02:14 PM
turbo*s2k's Avatar
Default Re: cooling fan not coming on! (b20turbojason)
Does anybody know where the relay is located to check that... I checked the fuses located near the battery and everything was good.
Old Oct 27, 2003 | 02:29 PM
the relay is in the same box that has the fuses in it it should say coolant fan relay on it or something like that
Old Oct 27, 2003 | 02:36 PM
turbo*s2k's Avatar
okay... I did check that and the fuse was fine. Any other suggestions. Thanks
Old Oct 27, 2003 | 04:15 PM
pro1342's Avatar
Most likely it's the thermoswitch.....
Old Oct 27, 2003 | 04:40 PM
mmuller's Avatar
Mad Scientist
Default Re: (pro1342)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pro1342 &raquo;</TD></TR><TR><TD CLASS="quote">Most likely it's the thermoswitch.....</TD></TR></TABLE>
Old Oct 27, 2003 | 04:59 PM
turbo*s2k's Avatar
Default Re: (mmuller)
thanks! That's what I was thinking too ...
Old Oct 28, 2003 | 05:05 AM
JimBlake's Avatar
Default Re: (TurboChrgd_Civic)
You said in your first post that you jumper the wires from the fan switch, and the fan runs. Right there you proved that the motor, relay, fuse, and wiring are ALL OK. That only leaves the switch...
Old Oct 28, 2003 | 08:05 AM
turbo*s2k's Avatar
Default Re: (JimBlake)
Thanks for all the help guys. All of a sudden out of the blue the fan started working again. I'll keep my eye on the temp gauge, and in the mean time I'll keep my manual switch hooked up!
Jonathan_ED3
45
Jun 14, 2019 05:53 PM
littleblue
Oct 14, 2008 04:44 AM
Black Paper Diary
May 19, 2006 03:16 PM
THE GAME IS THICK
Feb 12, 2004 04:08 PM
turbo*s2k
Oct 27, 2003 06:33 PM
