Solvent safe for valve guides?
Old Apr 20, 2006 | 03:34 PM
rbanke's Avatar
Default Solvent safe for valve guides?
Quick stupid question. Head is completly broken down and before I reassemble Id like to use my parts cleaner (mineral spirits) to hose down the head and get all the gunk out of the small areas. Does anyone know if that will have a negative effect on the valve guides?
Thanks
-Rich
Old Apr 20, 2006 | 04:49 PM
hondakevin21's Avatar
Default Re: Solvent safe for valve guides? (rbanke)
It shouldn't from my expirience, I also used a wire wheel to LIGHTLY remove carbon buildup but if you don't know how to properly do it don't. Valves are in there own little way fragile, so be careful with them. Good luck.
CRX89DX
13
Feb 13, 2009 06:49 PM
jdub db8
May 4, 2004 08:32 PM
Grandprix
Nov 7, 2003 05:25 PM
LudeyKrus
Jul 21, 2003 12:32 AM
