Need help Choosing a Turbo
I recently bought a Used Greddy sohc turbo kit and it took a **** oil was comming out of the damn turbine, i had oil in my IC Piping i even saw that turbine not spinning while the car was on once WTF. i kinda want to use the same Mani but dont want to rebuild this turbo cause i heard its better off just buying another.
Any one have some suggestions IM doing a Sohc build the guy i bought it from it buying it so im looking for a turbo Below $500
Anything would help i still want to use the Greddy Mani motor is a JdmD15B
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andysila »</TD></TR><TR><TD CLASS="quote">gt28rs
if you cant afford it..
http://www.mastercard.com</TD></TR></TABLE>
LOL how much are they i dont need the Best turbo on the market i just need a good and reliable one that bolts up to that manifold
kinda dont want to go with a dsm turbo anything else guys
What bolt pattern should i be looking for anway since im using the greddy mani?
How about the GT28r?
$795 --> http://store.yahoo.com/cheaptu....html
That's the turbo that Edelbrock uses in their kits. You may even be able to find it for cheaper than this, I've seen them go for less than $700 brand new.
You could look for a used one, I'm sure you could pick up a used one for less than $500 easy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMTRSPORTS »</TD></TR><TR><TD CLASS="quote">Now these come with an internal wastegate?</TD></TR></TABLE>
Yeah they do. The flapper is built into the turbine housing. You can have it welded shut if you want to use an external gate.
93hatchboosted
Aug 14, 2004 03:15 PM
