upgrading clutch question
im planning to buy a new clutch disc, do i have to buy a new preesure plate with it too, and do i have to go resurface the flywheel?
the reason why im planning to replace the clutch is my car will not go to any of the gears.
does anybody know where to buy the axle bushing that goes into the tranny my intermidiate shaft is leaking from there. or is there a part number for honda to go buy it.
car- 99 civic sedan ex
motor - B18c1 OBD1
tranny - Y80 gsr tranny
motor - B18c1 OBD1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kr »</TD></TR><TR><TD CLASS="quote">im planning to buy a new clutch disc, do i have to buy a new preesure plate with it too, and do i have to go resurface the flywheel?
I thought the pressure plate comes with a clutch when you buy one? You'll wan't to replace it.
You want to resuface the flywheel or get a light weight one. I'd also replace my water pump and timing belt as well.
I don't know what you prefer to do though, you know, if money permits and all.
Try this site for the axle bushing -http://www.hondaautomotiveparts.com/auto/jsp/mws/PartsSearch.jsp
Modified by monsterb18b at 6:33 PM 4/20/2006
well, while your planning on the down time, it might be nice to knock some things out while you have off work, school and just are in the maintence mood. But yeah, changing the timing belt is not at all necessary for a clutch install. God i hate clutch installs.
somebody's selling just the clutch and i really need one.
back to the topic do i need to replace the preesure plate or can i just install the new clutch and resurface the flywheel.
Well i had the same problems and i end up putting another tranny and is doin g the samething and the new tranny on has 40K miles.So im changing the clutch and see.But first im goin to bleed the lines more to see if it helps.I bleed the lines yesterday for like 20mins. and still the same.Would see.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JeffBro »</TD></TR><TR><TD CLASS="quote">No bad clutch can cause your car to not go into gear. If its warped really bad it can make it hard to go into gear.</TD></TR></TABLE>
wow my brother roasted his 240's clutch pretty bad...there was almost nothing left on there and all it did was not get to ground but it did go into gear...
I'm having a similar problem and I'm about to take my damned car to the shop.
It's my TOB/TOB fork. The thing won't return. Something you might want to look into.
I can go into 1st-5th without the clutch pedal and the car won't stall or move.
Da9austinRacing
Dec 18, 2010 10:25 PM
Libertariat
18
Jan 22, 2007 06:21 PM
Nextelbuddy
12
Jun 24, 2003 01:13 PM
