Need help fast Please!
get a syringe put some gas in it open throttle body while friend cranks shoot some in the TB that will tell you if you have a fuel issue
next get two friends have one crank and one hole spark plug wire to his tounge and touch the valve cover that will tell you if you have an ignition issue
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dank24 »</TD></TR><TR><TD CLASS="quote">well I just put the old ecu back in and it fired right up. I dont know what it could be. The ecu worked fine in my friends hatch</TD></TR></TABLE>
You prolly fried the other one. if this one works then just use it. now what ecu is in there right now and what one didn't work? basically i want to know if your running the right ecu at the moment or if your running the wrong one and it just seems to work for you.
I am converting ot OBD1 because I have a test pipe on my car and the 2nd O2 sensor keeps throwing codes. I put the orginal one back in and it works. What causes a ecu to be fried?
do basic order of operations...
Is the fuel pump priming first
Work from there would be my advice...
if so, try letting it prime once, letting the fuel systme pressurize, turn the key back, turn it back so it primes again, wait a second or two, then turn it off, then do it again (3rd time), then try starting ur car, u can usually tell that way if the fuel pump is going
Chopstikz
Jan 11, 2008 07:10 AM
