getting code 67 for having no cat? what to do?
Old Apr 19, 2006 | 11:34 AM
willyboyK20's Avatar
Default getting code 67 for having no cat? what to do?
I recently purchased a 02 type s and 3 days after driving it around the check engine light came on. When i jumped the service connector to get the code it was #67 which stands for "catalytic converter below threshold.." or something.
I jacked up the car and lo and behold in place of a cat is a test pipe.
Now the car doesn't seem to have any ill performance effects because of it but is their anything like an o2 sim or something i can do to get rid of the light
( I tried the ecu reset)
thanks
Old Apr 19, 2006 | 12:03 PM
Reborn's Avatar
Reborn_
o2 sim will do the trick
Old Apr 19, 2006 | 07:44 PM
Default Re: (Reborn)
how is it done?
Old Apr 19, 2006 | 10:36 PM
#1151's Avatar
Default Re: (willyboyK20)
wrap some tin foil around it, and let it hang outside of the cat, then get a bolt to plug the whole, trust me it works. you might want to ziptie the sensor somewhere though
Old Apr 20, 2006 | 11:34 AM
Default Re: (#1151)
and I do that to the second o2 sensor not the first one right?
Old Apr 20, 2006 | 11:39 AM
howangseg's Avatar
Default Re: getting code 67 for having no cat? what to do? (willyboyK20)
diy o2 sims, go to auot zone and get the 18mm spark plug non-fouler. theres a DIY on ephatch.com or k-series.com you might want to take a look. the tin foil sounds half assed. do it the right way the first way.
Old Apr 20, 2006 | 01:34 PM
HAMB0NE's Avatar
yeah do it the right way the first time. rh and test pipes will set off your cel, now worries, they are more flowing than any cat
Old Apr 20, 2006 | 01:41 PM
Reborn's Avatar
Reborn_
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by willyboyK20 &raquo;</TD></TR><TR><TD CLASS="quote">and I do that to the second o2 sensor not the first one right?</TD></TR></TABLE>
right, the first one isnt throwing any codes and should be kept in.
Old Apr 20, 2006 | 08:53 PM
.Kevin.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by howangseg &raquo;</TD></TR><TR><TD CLASS="quote">diy o2 sims, go to auot zone and get the 18mm spark plug non-fouler. theres a DIY on ephatch.com or k-series.com you might want to take a look. the tin foil sounds half assed. do it the right way the first way. </TD></TR></TABLE>
didnt work for me
Old Apr 23, 2006 | 02:39 AM
silver comet's Avatar
get kpro. haha an 02 sim should work fine.
brad98_teg
Mar 28, 2005 06:17 AM
stefanne3
Oct 19, 2004 02:09 PM
tegrunner
Sep 11, 2003 07:54 PM
Qwikrex
Aug 1, 2002 01:54 AM
AllMotorBLKITR731
Oct 17, 2001 12:39 PM
