Oh n0es, my new SOHC setup is up and running!
Old Apr 19, 2006 | 06:59 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Oh n0es, my new SOHC setup is up and running!
Before:
After:
I have a lot of cleaning up to do on the install (wiring, piping, vac. lines, etc.), but it runs pretty nicely for now...
Precision SC50 .48 a/r turbo, custom m4d tYtE ramhorn manifold (ceramic coated by Boost Factory), 3" downpipe & cat (KTeller 3" exhaust coming soon), Tial 35mm WG @ 7 psi, Crome-chipped ecu w/USB datalogging cable, DRAG III FMIC, ACT HDSS clutch kit, DSM 450cc injectors, etc. etc...
It runs great off the P2P map I'm running (JeffsBoostBin from Xenocron's directory). No CEL's, good oil pressure, no leaks (well, minor exhaust leak), and it pulls pretty well at only 5-6 psi!
3" exhaust, 10-11 psi, and dyno tuning are up next
Old Apr 19, 2006 | 07:05 AM
drintegra's Avatar
Default Re: Oh n0es, my new SOHC setup is up and running! (boostincoupe)
Nice, I love the 1cammers. Good luck and post some times and dyno.
Buzzbomb's Avatar
Congrats! It's a great feeling to finally start it up and know it runs.
Old Apr 19, 2006 | 07:08 AM
Default Re: Oh n0es, my new SOHC setup is up and running! (Buzzbomb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Buzzbomb &raquo;</TD></TR><TR><TD CLASS="quote">Congrats! It's a great feeling to finally start it up and know it runs.</TD></TR></TABLE>
You're tellin' me.
I ran a Greddy kit for almost 3 years, see the updated picture I added.
Old Apr 19, 2006 | 07:14 AM
SL0WEGG's Avatar
what happened to the rc injectors?
Old Apr 19, 2006 | 07:16 AM
Default Re: Oh n0es, my new SOHC setup is up and running! (boostedej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedej1 &raquo;</TD></TR><TR><TD CLASS="quote">what happened to the rc injectors?</TD></TR></TABLE>
They sat too tall in the IM for some reason, I found a thread that explains why. There was some seal we needed to put in, that we didn't have. Oh well, these will be fine for now, I can sell off the RC's and find a saturated set of them
Old Apr 19, 2006 | 07:19 AM
Charlie Moua's Avatar
<FONT COLOR="orange"> cool beans y0! </FONT>
well love the turbo choice, not too crazy about the manifold but for sure a nice DIY turbo kit. Keep honda-tech posted on your dyno results bro.
Charlie Neng Moua
Old Apr 19, 2006 | 07:22 AM
I Have an STD's Avatar
wrenchin'
AWESOME man. ive always loved your coupe. everything on it just flows together from me!
Old Apr 19, 2006 | 07:28 AM
Default Re: Oh n0es, my new SOHC setup is up and running! (I Have an STD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Have an STD &raquo;</TD></TR><TR><TD CLASS="quote">AWESOME man. ive always loved your coupe. everything on it just flows together from me!</TD></TR></TABLE>
Thanks bro
FYI, I'm running a steel D16Y7 oil pan on my Y8, and it seals up great!
Old Apr 19, 2006 | 07:45 AM
peiku's Avatar
glad to see my old y7 pan is working good. post them dynosheets when you get them.
Old Apr 19, 2006 | 07:46 AM
gitwidit's Avatar
It's about time
for you!
quit boostin on the basemap and get that thing tuned!
Default Re: Oh n0es, my new SOHC setup is up and running! (peiku)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peiku &raquo;</TD></TR><TR><TD CLASS="quote">glad to see my old y7 pan is working good. post them dynosheets when you get them.</TD></TR></TABLE>
I should be headed to Full-Blown for a couple dyno pulls here soon.
Old Apr 19, 2006 | 08:09 AM
unsungsohc's Avatar
Looking good man. Yeah the whole fuel rail situation on those Y8 manifolds suck. With a little modification i ended up runnin my b7 fuel rail Get some numbers dyno numbers up!
Old Apr 19, 2006 | 08:11 AM
Default Re: Oh n0es, my new SOHC setup is up and running! (unsungsohc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unsungsohc &raquo;</TD></TR><TR><TD CLASS="quote">Looking good man. Yeah the whole fuel rail situation on those Y8 manifolds suck. With a little modification i ended up runnin my b7 fuel rail Get some numbers dyno numbers up!</TD></TR></TABLE>
I'm comin' for YOU in June! I want $500
225 BFG's and a 3" KTeller are coming up next week
Old Apr 19, 2006 | 08:22 AM
Quad-Damage's Avatar
Might want to clean up your vac lines just a bit, run the under the pipes and under the intake manifold then come up it will look alot cleaner. I bet u love the power of the SC50 to the 15g, but now u hate the lag
Old Apr 19, 2006 | 08:26 AM
Default Re: Oh n0es, my new SOHC setup is up and running! (Quad-Damage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quad-Damage &raquo;</TD></TR><TR><TD CLASS="quote">Might want to clean up your vac lines just a bit, run the under the pipes and under the intake manifold then come up it will look alot cleaner. I bet u love the power of the SC50 to the 15g, but now u hate the lag </TD></TR></TABLE>
Yeah, I have a lot of work to do with the vacuum lines. I'm not sure if I want to run the GE vacuum manifold I have, as I'm running the WG to the compressor, and the BOV to the brake booster. The boost gauge is running off the IM cruise control line (which I don't use).
I LOVE the SC50, because it pulls where my 15G never did
However, I do hate getting used to the lag. It's like sppooollllllnoise PULLLLLLLLLLLL WAAAAAAAAAAAAAAAA!!!!!!!!!
I need to get the 3" KTeller on there soon, and get it dyno tuned at more than 5-6 psi
Old Apr 19, 2006 | 08:28 AM
MRturbo's Avatar
Great setup!! Post those dyno numbers when you get it!
Old Apr 19, 2006 | 09:00 AM
JDMs1eeper's Avatar
Default Re: Oh n0es, my new SOHC setup is up and running! (MRturbo)
Looks like a nice upgrade
Old Apr 19, 2006 | 09:12 AM
kabaroo's Avatar
Default Re: Oh n0es, my new SOHC setup is up and running! (JDMs1eeper)
making progress fnan!
As for the lag on that turbo... i never had a problem since i had the same turbo/mani. I would rather wait a bit for boost than to have it run out of breath 1000rpm before redline *cough* 15G *cough*
Old Apr 19, 2006 | 09:41 AM
Default Re: Oh n0es, my new SOHC setup is up and running! (kabaroo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kabaroo &raquo;</TD></TR><TR><TD CLASS="quote">making progress fnan!
As for the lag on that turbo... i never had a problem since i had the same turbo/mani. I would rather wait a bit for boost than to have it run out of breath 1000rpm before redline *cough* 15G *cough*</TD></TR></TABLE>
Well you have to understand that I'm still running a 3" downpipe -&gt; 3" cat -&gt; 2.25" DC Sports cat-back exhaust, so that has a lot to do with spool-up. And I have a couple exhaust leaks to fix (my fault).
But I really do like the fact that I can actually rev it out and make power to redline and beyond
CRX MASE
Aug 16, 2007 11:00 PM
eazycivic
Aug 21, 2005 06:49 AM
crazyimport
May 14, 2004 08:52 AM
Zer0DazE
May 13, 2004 11:57 AM
Tinker219
Apr 24, 2003 08:39 AM
