Fuel leaking help...
Old Apr 19, 2006 | 04:33 AM
garyc17's Avatar
Default Fuel leaking help...
After driving in a hot day, I will get fuel smell coming from my engine bay. I had the fuel feed line going to the fuel rail tightened(at the rail) just a few weeks back. It solved the fuel leak/ smell which was very strong regardless of the temperature. I checked the same place and there appears to be no leak. What could be the problem? I can't seem to trace the source of the leak with my nose.
Old Apr 19, 2006 | 04:35 AM
RTW DC2R's Avatar
check filter and line fittings
check your injector seals
if using aem fuel rail, check the allen bolt on top
check fuel return line
just follow the fuel trail you should be able to narrow it down.
Old Apr 19, 2006 | 04:36 AM
Dave_B's Avatar
Default Re: (clip the apex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clip the apex &raquo;</TD></TR><TR><TD CLASS="quote">check your injector seals</TD></TR></TABLE>
Yep, the o-rings leak sometimes.
Mario.
Jun 22, 2006 07:32 PM
EFin' Kyle
Apr 27, 2006 11:43 PM
EK FLY
Jan 6, 2006 05:04 PM
LBR92DA-T
Oct 25, 2003 02:21 AM
