cam timing adjustment on a sohcvtec turbo
Old Apr 18, 2006 | 10:23 PM
cliff666's Avatar
Default cam timing adjustment on a sohcvtec turbo
wats the point of having a cam gear on a sohcvtec? from wat i was told the dizzy is cam driven so isnt that actually adjusting the cam timing also with the ignition timing? just curious because my car's cam gear is adjusted 2 degrees advanced and i was wondering if i will have to adjust it by the cam gear or can i do it by the distributor? just curious and wondering because i just remembered this and tuning is being done tom morning
Modified by bruceHungLO at 11:57 PM 4/18/2006
Old Apr 18, 2006 | 11:05 PM
Stop the Beast's Avatar
Default Re: cam timing adjustment on a sohcvtec turbo (bruceHungLO)
cam and dizzy timing are independent but, I haven't seen great gains in cam tuning on a sohc. you should see more gains in a non-vtec. I woudn't spend the money on an adjustable cam gear for the vtec sohcs.
Old Apr 18, 2006 | 11:07 PM
cliff666's Avatar
Default Re: cam timing adjustment on a sohcvtec turbo (Stop the Beast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stop the Beast &raquo;</TD></TR><TR><TD CLASS="quote">cam and dizzy timing are independent but, I haven't seen great gains in cam tuning on a sohc. you should see more gains in a non-vtec. I woudn't spend the money on an adjustable cam gear for the vtec sohcs.</TD></TR></TABLE>
ya but the cam gear was already on the car thats wat i mean. so are u saying i should bring the cam gear back to stock for tuning? so it cant be affected by adjusting the distributor?its advanced 2 degrees now i just want to bring it back to 0
cliff666
Apr 19, 2006 10:49 AM
mrlover
Dec 7, 2005 08:21 PM
Red_Si
Apr 20, 2004 07:21 PM
slowman
Nov 29, 2002 05:27 PM
