B16 tranny Rebuild.
Old Apr 18, 2006 | 08:50 PM
JDM B16A's Avatar
Default B16 tranny Rebuild.
Okay, so my B16A tranny is shot out. My 3rd and 5th gear grinds like crazy when i shift into them. Also my 4th gear is starting to give out. I'm aware that the synchros are the reason for their grinds. This is what I am planning on doing. Put LSD, replace ALL 1st to 5th synchros. How much would the parts cost me? Just the part not for the labor! Also, do you think its worth rebuilding or should i just get a whole new tranny with LSD all together?
Old Apr 18, 2006 | 09:03 PM
D.Dappa's Avatar
Default Re: B16 tranny Rebuild. (JDM B16A)
honda sells the syncros in set 1-2nd gear, 3-4th and 5-R so your preety much going to have to buy all the syncros(sleeve set) honestly it might be cheaper to just buy a used tranny with low miles...
Old Apr 18, 2006 | 09:06 PM
EG2Driver's Avatar
Default Re: B16 tranny Rebuild. (D.Dappa)
http://sms-products.com/Construction.html
look under trannies, rebuilt kits are there will the syncros. Unless u wanna stay OEM, then i'd try this.
Old Apr 19, 2006 | 10:44 AM
Mista Bone's Avatar
D Tranny Guru
B trannys, when the synchros are grinding, the dog teeth on the gears are already damaged. You'll need to replace the gearsets also.
Expect $500+ in parts alone.
Old Apr 19, 2006 | 10:45 AM
JDM B16A's Avatar
So those are the only options huh? Do you guy think its worth rebuilding? I know D.Dappa said no but what about u DeadEnd?
Old Apr 19, 2006 | 12:51 PM
EG2Driver's Avatar
Default Re: (JDM B16A)
well, seeing what Mista Bone said, if ur syncros are bad, theres more to it. I would suggest trying to find a used tranny or find one with a busted case and swap the internals. Im sure you can find a crashed B-seried Honda with a cracked case/bell and just swap the internals....anyways, just my 2 cents. Good luck with the project!
Old Apr 19, 2006 | 02:55 PM
JDM B16A's Avatar
Thank you for all your helps. Considering what everyone on HT is telling me I will just buy a use one. Thank you once again.
Old Apr 19, 2006 | 03:03 PM
civicguy66442's Avatar
i have a jdm b18c1 tranny with lsd for sale it has a excedy stage 1 clutch and flywheel 37000 miles shifts smooth as silk with shift linkage $900 you can email me at civicguy66442@yahoo.com
Old Apr 19, 2006 | 04:53 PM
Rickcrx's Avatar
I was having the same problems and id call honda and they said for a whole set syncros was $600 + labor and other part i have to buy to do the rebuild.If u rebuild the tranny u have to rebuild everything cus u would end up having the same problems.So ur best bet is buy another tranny.I know it sux cus i end up buying another one and they arent cheap.Good luck.
Old Apr 19, 2006 | 04:58 PM
E46Kid's Avatar
Default Re: (Rickcrx)
yeah my damn syncrhos are giving up as well my second and third scratch's, i agree with others were just gonna have to buy a used tranny or get it rebuilt and have better luck without it giving out sooner
bigboom
Transmission & Drivetrain
Apr 12, 2010 10:34 PM
blasterman87
Jul 16, 2009 08:30 AM
hialeahzbg
May 31, 2005 11:20 PM
Echo7847
May 23, 2004 05:43 PM
