Auto Meter Gausge Wiring
Old Apr 18, 2006 | 06:38 PM
Akalima's Avatar
Default Auto Meter Gausge Wiring
Hey guys I'm just trying to wire my atuo meter gauges to my dash lights on my 99 gsr. I looked at my fuse panel and located the fuse for the dash lights. But there is no way im gonna find those specific wires. My budy was telling me about a pigtail system for the big fuses were u just put the harness in where the fuse goes. Just wondering if any of u have come across this or if u have a better sugestion. THX
Old Apr 18, 2006 | 06:50 PM
Miracle's Avatar
Default Re: Auto Meter Gausge Wiring (Akalima)
You can find an adapter in pretty much any parts store, and what it does is slip over one of the prongs of the fuse, and it has a female adapter on the end. Ive seen em in bullet style, and just a plain connector.
Another way to do it, the way i did mine is do a test on any wire that is only hot when the ignition is on, line the radio power wire, and splice into that. That way, youll get illumination when the ign, is on.
Old Apr 18, 2006 | 08:59 PM
Akalima's Avatar
Default Re: Auto Meter Gausge Wiring (Red7thGen_ex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red7thGen_ex &raquo;</TD></TR><TR><TD CLASS="quote">Another way to do it, the way i did mine is do a test on any wire that is only hot when the ignition is on, line the radio power wire, and splice into that. That way, youll get illumination when the ign, is on.</TD></TR></TABLE>
Yah i was thinking that but i only want the gauges to light up when the dash lights are on i.e. night time. Maybe i could tie into the dimmer switch.
Old Apr 19, 2006 | 02:23 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
You can grab illumination at the back of the dimmer switch, or any lighted device, including the parking lights. I believe the wire color is red w/ black.
If you are looking at your fuse box, there are 5 or so empty male terminals. One of them is a parking light signal. Use that.
Old Apr 19, 2006 | 06:00 AM
Miracle's Avatar
Default Re: Auto Meter Gausge Wiring (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">You can grab illumination at the back of the dimmer switch, or any lighted device, including the parking lights. I believe the wire color is red w/ black.</TD></TR></TABLE>
Yeah that would work too. Just find the hot wire going to one of the parking lights and tap into that. Just test light anything you want to use to make sure its only hot with the ign on, and parking/headlights on.
Old Apr 20, 2006 | 02:55 PM
H24A96EK's Avatar
i used the dimmer switch on mine. have to use the two outer wires of the switch.
Old Apr 20, 2006 | 10:09 PM
Akalima's Avatar
Default Re: (H24A96EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H24A96EK &raquo;</TD></TR><TR><TD CLASS="quote">i used the dimmer switch on mine. have to use the two outer wires of the switch.</TD></TR></TABLE>
how did u get to ur dimmer switch it almost looks like i have to remove the dash
Old Apr 21, 2006 | 12:03 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Default Re: (Akalima)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Akalima &raquo;</TD></TR><TR><TD CLASS="quote">
how did u get to ur dimmer switch it almost looks like i have to remove the dash </TD></TR></TABLE>
Should just pop out.
ej1 pilot
Audio / Security / Video
Jun 6, 2004 08:55 AM
cory1269
Mar 16, 2004 08:52 AM
DOHCRX
Aug 10, 2003 04:31 AM
2camsaam
Mar 12, 2003 03:55 AM
