What rear sway are you guys using?
Old Apr 18, 2006 | 03:49 PM
8atman's Avatar
Default What rear sway are you guys using?
There isnt much of a market out there for our cars but i wanted to know what rear sway bars you guys are using how do you like them? How much were they?
thanks
Old Apr 18, 2006 | 03:55 PM
88 rex's Avatar
Default Re: What rear sway are you guys using? (father figure)
Suspension techniques
Old Apr 18, 2006 | 04:32 PM
jdmazm's Avatar
Default Re: What rear sway are you guys using? (88 rex)
Energy Suspension front and back.
Old Apr 18, 2006 | 04:33 PM
8atman's Avatar
Default Re: What rear sway are you guys using? (jdmazm)
I heard alot of people dont use the front creats alot of under stear. What do you think of yours, and how much did you get yours for, and where from?
thanks
Old Apr 20, 2006 | 10:53 AM
jdmazm's Avatar
yeah thats true.. After removing it I noticed a huge difference in understeer. It tends to be a little too tight but works great at the track with some sticky tires. I take them off when daily driving, but at the track it helps believe it or not.
you can order from their website, all their prices are there. http://www.energysuspension.com
Old Apr 20, 2006 | 12:14 PM
Tyson's Avatar
uh.... energy suspensions doenst make swaybars...
suspension techniques makes swaybars. probably the more common, because they supply their own bracket for non si chassis.
i completely dont recommend getting the front bar, 22mm solid is way too thick. and yeah, some ppl would prefer to lower the strength of the front bar with an HF bar which is thinner and hollow.
i use a 19mm solid sedan bar front, and 22mm mugen rear bar. both fit like stock.
Old Apr 20, 2006 | 12:45 PM
HBoy's Avatar
Default Re: What rear sway are you guys using? (Tyson)
I made a rear sub frame support and used the rear bar off a 99 SiR (Canadian).
Can't remember the size but it is much stiffer that the one they make for our cars. I find it works quite well with the stock front bar (89 DX)
Old Apr 20, 2006 | 12:51 PM
sauceja's Avatar
Or you could buy Civic Crx Si Lower control arms that have the sway bar mount in them.
Old Apr 20, 2006 | 01:07 PM
red_EF9Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmazm &raquo;</TD></TR><TR><TD CLASS="quote">Energy Suspension front and back.</TD></TR></TABLE>
x2
anybody have their rear endlinks come loose on the rear w/ the st's??
Old Apr 20, 2006 | 01:09 PM
Tyson's Avatar
Default Re: What rear sway are you guys using? (sauceja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sauceja &raquo;</TD></TR><TR><TD CLASS="quote">Or you could buy Civic Crx Si Lower control arms that have the sway bar mount in them.</TD></TR></TABLE>
that would be nice, except it doesnt solve the issue with mounting it to the chassis.
Old Apr 20, 2006 | 01:38 PM
fireant's Avatar
Tyson, how's the Mugen compare to ST in stiffness and weight?
I know the ST is just about 12lbs more than stock and lots of people run with it on full soft... you've probably seen my posts about stiffening the Stock CRX bar, because I'm kinda wondering if there's somethiing lighter I could be using.
Old Apr 20, 2006 | 01:45 PM
Tyson's Avatar
Default Re: What rear sway are you guys using? (fireant)
its obviously heavier than stock but doesnt require any special bracket or endlink like the ST boat anchors. i never compared to ST. i had something similar to ST itself, i was glad to replace it with my mugen.
intrax and neuspeed makes 22mm rear swaybars that are direct fit. tanabe i hear makes a direct fit thats also lighter than normal. lastly, ST makes a DA rear swaybar thats direct fit, 19mm. might be worth looking into as well.
i just received a SiR rear swaybar. it should be 18mm. havent gotten it out of the box yet to confirm. why do i have it? dunno, ijust like collecting junk...
Old Apr 20, 2006 | 03:21 PM
EJ1 wilcox's Avatar
I have a DA front bar with Energy Suspension endlinks and a ST rear bar at the stiffest setting.
The car is pretty neutral and well balanced. It's very predictable on the street but on the autocross course it seems I understeer a bit more than I would like. Maybe it's my driving, I don't know. I think I'm going to try removing the DA front bar for the next event and run with just the ST rear on full stiff. Hopefully that brings the *** end around the cones a little better.
Old Apr 20, 2006 | 03:40 PM
fourthgenhatchB17's Avatar
Default Re: What rear sway are you guys using? (red_EF9Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red_EF9Si &raquo;</TD></TR><TR><TD CLASS="quote">
anybody have their rear endlinks come loose on the rear w/ the st's??</TD></TR></TABLE>
The rear endlinks are heim joints. What do u mean by coming loose? My original pieces developed play in the joint themselves, so i replaced them with higher grade stuff.
Old Apr 20, 2006 | 03:49 PM
Mugencrxsir1's Avatar
Default Re: What rear sway are you guys using? (fourthgenhatchB17)
Stock SI
Old Apr 20, 2006 | 04:08 PM
vegaskurt's Avatar
Default Re: What rear sway are you guys using? (Mugencrxsir1)
I made my own brackets to fit a DA sway bar with DA LCA's on my DX. I took it off just before getting my ksports and to be honest I dont miss it.
Old Apr 20, 2006 | 07:01 PM
mahatma's Avatar
Default Re: What rear sway are you guys using? (vegaskurt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vegaskurt &raquo;</TD></TR><TR><TD CLASS="quote">I made my own brackets to fit a DA sway bar with DA LCA's on my DX. I took it off just before getting my ksports and to be honest I dont miss it.</TD></TR></TABLE>
How was the camber with those LCA's?? No difference?
Old Apr 20, 2006 | 07:02 PM
Crx Jimmy's Avatar
25mm custom made, with heim end links, works great for auto-x
Old Apr 20, 2006 | 08:12 PM
8atman's Avatar
Default Re: What rear sway are you guys using? (Crx Jimmy)
hook it up man...
Prudz_lude
Jun 26, 2013 05:22 AM
murderedrsx
Sep 27, 2011 10:51 PM
EFstyle
10
Mar 1, 2008 06:38 AM
EFstyle
14
Aug 23, 2007 06:18 PM
