Problem with valve clearance
Old Apr 18, 2006 | 01:11 PM
pentaq's Avatar
Default Problem with valve clearance
I had to replace the headgasket in my Accord Wagon, so I did it. The head was resurfaced, valve seats reconditioned . I installed everything and the last thing to do was adjusting the valve lash. As usual I started from the first cylinder- intakes done, the first ehxaust valve done, second... ups... I can't stick my feeler gauge at all... I unscrewed the adjusting screw to the very top and still no gap... WTH? I turned the crank a few times- no strange sounds, everything smooth... Hmmm Went to the third cylinder and the story repeated... One ex valve has no gap... I left it like it was and adjusted 2 and 4 cylinder valves without any problems.
So after that I was left with two exhaust valves with no gaps... Of course they tap when the engine is on. What to do?
Old Apr 18, 2006 | 01:45 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Problem with valve clearance (pentaq)
Those screws are quite long. Do you have any pictures?
Old Apr 19, 2006 | 12:15 AM
pentaq's Avatar
Default Re: Problem with valve clearance (Dogginator)
nope- I didn't take any.
Just they are unscrewed all the way and there is no gap between rocker and valve stem.
Old Apr 19, 2006 | 08:19 AM
civicstar's Avatar
make sure when u turn the cam to the next set of valves, u are doing the right one. here is the order, Top ded Center Up is 1. then next when goes 3, then goes 4 then 2. make sure u rotate the cam counter clockwise.
Old Apr 19, 2006 | 08:54 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Problem with valve clearance (civicstar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicstar &raquo;</TD></TR><TR><TD CLASS="quote">make sure when u turn the cam to the next set of valves, u are doing the right one. here is the order, Top ded Center Up is 1. then next when goes 3, then goes 4 then 2. make sure u rotate the cam counter clockwise.
Good point.
Old Apr 19, 2006 | 11:58 AM
pentaq's Avatar
C'mon read my initial post carefully. I did adjustment several times, so I'm sure I did all the procedure well.
Old Apr 19, 2006 | 01:11 PM
Dogginator's Avatar
Daisy... Daisy...
No offence intended. Are you sure that the cam timing is correct? Is there any point during the engine rotation where you can insert a feeler gauge into the valves for cylinders 1 and 3?
Old Apr 19, 2006 | 01:18 PM
pentaq's Avatar
No, I can't insert the feeler gauge at all. But it's only ONE of two exhaust valves... It's not possible even if timing is bad. the second one is OK. It must be something different
Old Apr 19, 2006 | 01:25 PM
Dogginator's Avatar
Daisy... Daisy...
Did the machine shop check the valve stem height?
Old Apr 19, 2006 | 01:27 PM
pentaq's Avatar
Doubt it. The guy was assembling the head while I was waiting.
Old Apr 19, 2006 | 01:51 PM
Dogginator's Avatar
Daisy... Daisy...
This may help:
http://www.hondahookup.com/manuals/
Chuonthis069
Oct 22, 2012 08:15 PM
lazyxmofo
May 23, 2012 07:04 PM
Robotoyaki
Jan 1, 2010 02:10 PM
Ri5e
Aug 9, 2002 07:48 AM
