Partial DIY and pictures of the D16's PCV valve
Old Apr 18, 2006 | 12:51 PM
.Ry's Avatar
.Ry
Default Partial DIY and pictures of the D16's PCV valve
Well I know when I replaced my PCV valve I couldnt find it. I searched on HT, but the few pictures I was able to find were taken down. So while changing my oil today I took a few quick pictures. As its getting warmer and alot of people forget about changing this important maintenence item. Its brief but it should prove helpful. This is for a D16Y8, but I belive most D series should be about the same. On some the PCV valve is considered "in-line". Meaning its not plugged into the box, but its in the hose which is shown in blue.
Shown below is a picture of the PCV valve in its black box. The red is the PCV valve, just above the oil filter threads. The blue is the hose that runs up above the intake manifold shown later.
Again, shown below is another picture just like your looking at it from the ground.
Below is where the PCV valve tube comes throught the intake manifold.
DIY: Take a flat head screwdriver and carefully pry out the PCV valve from the black box***. Go up above the car and carefully pull the hose through the intake manifold and the PCV valve will come out. CAREFULLY take the old on out. Its brittle so please be gentle. Put the new one in the tube. Stick the tube back down the hole so you can reach it while laying on the ground. Stick it back in the black box and your good to go.
*** On some D-Series the PCV valve is "in-line". Meaning you will have to seperate hose on each side of the PCV valve. Simply disconnect the hose from the PCV valve to the black box, and pull the other tube and PCV valve up through the hole.
Old Apr 18, 2006 | 12:56 PM
Luserkid's Avatar
Default Re: Partial DIY and pictures of the D16's PCV valve (turner7205)
Nicely done, and just to add this is the same for B series as well, that little oil can in the back holds the PCV, some motors arent on the side like yours some are on the top.
Old Apr 18, 2006 | 01:19 PM
5 Skware's Avatar
I missed the boat
Default Re: Partial DIY and pictures of the D16's PCV valve (Luserkid)
Good stuff man....this should be in the helpful links sticky thread at the top
Old Apr 18, 2006 | 01:22 PM
.Ry's Avatar
.Ry
Default Re: Partial DIY and pictures of the D16's PCV valve (5 Skware)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5 Skware &raquo;</TD></TR><TR><TD CLASS="quote">Good stuff man....this should be in the helpful links sticky thread at the top </TD></TR></TABLE> Wouldnt hurt, I tried to word the title so people could easily find it if they searched. Ive done all the maintence items to my car, but I get in a hurry and forget to take pictures.
Old Apr 18, 2006 | 02:41 PM
Soccerking3000's Avatar
the d16z6 pcv valve is actually a right angle thing and is connected at the point where the line goes through the intake manifold, just an fyi
Old Apr 18, 2006 | 02:43 PM
Bense's Avatar
Default Re: Partial DIY and pictures of the D16's PCV valve (Soccerking3000)
okay seriously. I have written complex tranny pages, and other ****, but I have NO clue what the hell that "black box o' mystery" does.
Can someone please explain to me what it's for?
Old Apr 18, 2006 | 02:45 PM
HXvtec's Avatar
good stuff x2. i didnt know there was a pcv valve after 95 on the d series.
Default Re: Partial DIY and pictures of the D16's PCV valve (Bense)
its just a baffled box that helps vent crankcase pressure when the car is in vacuum (aka all the time)
Old Apr 18, 2006 | 02:59 PM
CivicBlack's Avatar
Default Re: Partial DIY and pictures of the D16's PCV valve (HXvtec)
Um i didn't know this needed to be maintained. . .what exactly is the purpose of the PCV valve. . and when (mileage) (or whatever) should i look to replace it?
Old Apr 18, 2006 | 03:10 PM
Bense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">its just a baffled box that helps vent crankcase pressure when the car is in vacuum (aka all the time)</TD></TR></TABLE>
NO WONDER I WAS BAFFLED BY IT!
Old Apr 18, 2006 | 03:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">NO WONDER I WAS BAFFLED BY IT! </TD></TR></TABLE>
lol
Old Apr 18, 2006 | 07:23 PM
.Ry's Avatar
.Ry
NO WONDER I WAS BAFFLED BY IT! </TD></TR></TABLE> haha, thanks for the comments.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">the d16z6 pcv valve is actually a right angle thing and is connected at the point where the line goes through the intake manifold, just an fyi </TD></TR></TABLE> Good stuff man, well if they dont see it there, then they know where else to look!
Old Sep 2, 2006 | 10:03 AM
.Ry's Avatar
.Ry
just throwing it back up top for people
Old Sep 2, 2006 | 02:04 PM
mikey-ej7's Avatar
do I need to jack up the car to change the pcv valve?
i couldnt find mine, so i did a search.. thanks for the tread
Old Sep 2, 2006 | 02:35 PM
.Ry's Avatar
.Ry
Default Re: Partial DIY and pictures of the D16's PCV valve (mikey-ej7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikey-ej7 &raquo;</TD></TR><TR><TD CLASS="quote">do I need to jack up the car to change the pcv valve?
i couldnt find mine, so i did a search.. thanks for the tread</TD></TR></TABLE> Yeah, I do it when im changing the oil/filter makes it alot easier.
Old Sep 2, 2006 | 04:36 PM
sicones's Avatar
I just replaced my PVC valve the other day. It had 50,000 miles on it, and let me tell you it was perfectly clean I should have just hit it with some brake cleaner but I wanted to break it open to see what was inside. The OEM honda ones are spring loaded if you get an aftermarket piece of **** it's not. You can tell if the PCV valve is still good if you shake it and you hear it rattle, obviously your not going to hear the OEM spring loaded one rattle.
Old Mar 23, 2007 | 02:47 PM
cal6531's Avatar
Default Re: Partial DIY and pictures of the D16's PCV valve (.Ryno)
Old threads contain the best info
I snapped my PCV valve in my EK (located in the DUMBEST place ever designed on a car, under the intake manifold and above the oil filter.)
1. Jacked up car
2. Removed oil filter
3. Tried prying the PCV off with a screwdriver. Note: Do not use screwdrivers, see #4.
4. It broke into 2 pieces, got mad and used vice grips making it worse.
So now its really stuck in there, yup I am an idiot. Looks like I am will have to spend a few hours tearing apart my intake manifold.
What are my options? At this point I' thinking !@#$ the valve.
Old May 5, 2007 | 08:32 PM
BlkCB550SC's Avatar
Default Re: Partial DIY and pictures of the D16's PCV valve (cal6531)
Just replaced the PCV valve today as it was time to change my oil. Unfortunately I could only get the low-end one. Still, it fixed my idle (I was running around 500). The pics on this thread really helped! Still, it's a pain to take the old valve off and put the new one on!
Old May 22, 2007 | 07:02 AM
Mooneyes13's Avatar
Default Re: Partial DIY and pictures of the D16's PCV valve (CivicChuk)
in on this
Old May 22, 2007 | 08:04 AM
amej8's Avatar
What exactly is a PCV valve supposed to look like when it's "bad"? And how does it even get dirty if it's just a vacuum?
My y8 idles around 4/500 when fully warmed up and it sounds bad... I need to change this on my next oil change. They're like what....$20 or so?
Old May 22, 2007 | 08:19 AM
EE_Chris's Avatar
Default Re: (amej8)
The oil/air seperator black box doesn't do the best of jobs. So there is still some oily air going through the PCV valve and into the intake. You can't tell a PCV valve is good or bad by looking at it. You have to remove it and blow through it...each way. It should only flow one way and not the other.
Old May 22, 2007 | 08:23 AM
amej8's Avatar
Thanks for the info .
But figuring my car has 178,600 miles and that it's never been changed, I guess I could spend the $20 or so and replace it.
Old May 22, 2007 | 08:38 AM
instructor74's Avatar
Default Re: (amej8)
I like where min is on the d16z right on top of the intake manifold. I think its time to check mine I noticed a good bit of oil residue in the intake the other day. Maybe I will just put in a oil catch can and filter instead might help a bit more then just running the pcv system
JPRhome
17
Nov 17, 2014 06:02 PM
zeroek
Apr 3, 2011 04:07 PM
vteg98
Oct 24, 2006 07:05 PM
Turbochargedcivic
Aug 2, 2006 08:04 AM
1.8T_EG
Nov 19, 2002 03:05 AM
