... clogged pcv valve
Old Nov 5, 2002 | 02:23 PM
1.8T_EG's Avatar
Default ... clogged pcv valve
... what problems can come up because of a clogged pcv valve?... i remember reading somewhere (but cant find the topic anymore) about a clogged pcv valve causing oil and coolant leaks, but i am not sure... anyways, i just wanted to know (kinda got me paranoid since i have never un-clogged my pcv valve before)... if anyone has any info, i would appreciate it... thanks...
Old Nov 5, 2002 | 02:52 PM
MiraiZ's Avatar
Default Re: ... clogged pcv valve (1.8T_EG)
High oil consumption followed by blue smoke
blow by, high crankcase pressure
oil soaked air filter
oil in the charge pipe
poor mileage
Old Nov 6, 2002 | 08:08 AM
1.8T_EG's Avatar
Default Re: ... clogged pcv valve (MiraiZ)
poor mileage
woah... all of these things can be caused by a clogged pcv valve?... also, (might be a n00bie question) how would i go about unclogging the pcv valve?... thanks...
Old Nov 6, 2002 | 08:18 AM
JT's Avatar
JT
Either use carb/pcv cleaner to clean until the pcv rattles again, or simply replace the pcv valve.
Old Nov 19, 2002 | 03:05 AM
IntEGNYC's Avatar
Default Re: ... clogged pcv valve (JT)
Replace the PCV valve... theyre only $2 and change.
95B18Teggy
Jun 11, 2014 08:46 PM
justint
Dec 27, 2006 04:33 PM
Layziebtnh055
Apr 11, 2004 07:41 AM
phillycx
Sep 3, 2002 07:05 PM
Farnsrocket
Mar 4, 2002 10:41 AM
