Inline oil filter to turbo
Old Apr 17, 2006 | 03:58 PM
alpha's Avatar
Default Inline oil filter to turbo
I wanted to see how many people run an inline oil filter to their turbo. Pictures would be great too Below is a picture of my inline oil filter. It's to the right of the exhaust manifold. Oil is fed from a Greddy oil adapter to the inline oil filter to the oil feed.
Old Apr 17, 2006 | 04:03 PM
HamiltonRex's Avatar
Default Re: Inline oil filter to turbo (0x64)
Honda filter does a well enough job filtering oil.
Old Apr 17, 2006 | 04:04 PM
nickromeo's Avatar
arent u worried about that filter getting clogged up and stopping all the oil going to the turbo, a normal filter is changed every 5K and they are alot bigger,
how often do u replace ur inline filter?
Old Apr 17, 2006 | 04:05 PM
alpha's Avatar
Default Re: Inline oil filter to turbo (HamiltonRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex &raquo;</TD></TR><TR><TD CLASS="quote">Honda filter does a well enough job filtering oil.</TD></TR></TABLE>
Not everyone runs an oil adapter so they are not getting filtered oil. I will take it apart in a couple months and post pictures of the filter.
Old Apr 17, 2006 | 04:06 PM
alpha's Avatar
Default Re: Inline oil filter to turbo (nickromeo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickromeo &raquo;</TD></TR><TR><TD CLASS="quote">arent u worried about that filter getting clogged up and stopping all the oil going to the turbo, a normal filter is changed every 5K and they are alot bigger,
how often do u replace ur inline filter?</TD></TR></TABLE>
It's easy enough to open and check every oil change. A lot of DSM's here run them with no problems. Was curious if a lot of Honda people run them as well.
Old Apr 17, 2006 | 05:43 PM
Justin Jones's Avatar
That's pretty trick.
Old Apr 17, 2006 | 06:04 PM
mtber's Avatar
Old Apr 17, 2006 | 06:13 PM
tony1's Avatar
Default Re: Inline oil filter to turbo (mtber)
If you just run it from the factory sending unit hole then it's filtered.
Old Apr 17, 2006 | 06:45 PM
seen4ever's Avatar
Default Re: Inline oil filter to turbo (tony1)
even if it comes from an unfiltered source from the oil filter adaptors, the filter does filter the oil in the system, so the oil in the pan is filtered, just won't be an instant filter.
Old Apr 17, 2006 | 07:36 PM
xsi-t's Avatar
does using the filter void warantyive heard yes it does do to them calling it blockage
Old Apr 18, 2006 | 02:55 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">If you just run it from the factory sending unit hole then it's filtered.</TD></TR></TABLE>
Exactly what i do.
Old Apr 18, 2006 | 09:27 AM
99B16Si's Avatar
i think its over kill. id also be worried about a pressure change going across that
Old Apr 18, 2006 | 09:32 AM
Fitti's Avatar
Default Re: (xsi-t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xsi-t &raquo;</TD></TR><TR><TD CLASS="quote">does using the filter void warantyive heard yes it does do to them calling it blockage</TD></TR></TABLE>
yeah you are right. You have to be careful of oil starvation when using one of these. But I think if you are collecting enough material in one of these filters to block oil flow that you motor has a lot bigger issues going on
Old Apr 18, 2006 | 09:37 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (Fitti)
for the longest time on buick turbo's harry sold, there was no warranty unless you had his turbo filter setup. i dont know if this is still true or not.
Old Apr 18, 2006 | 10:13 AM
yee SERIOUS's Avatar
damn! how hot does your dipstick get?
happynoodleboy
Feb 20, 2008 06:34 PM
lazykiwi
Dec 26, 2005 09:38 PM
skunk2finatic
Oct 28, 2004 10:05 PM
flipp117
Aug 10, 2004 11:41 AM
dclub01
May 1, 2003 03:22 PM
