Will header make v-tec louder?
Old Apr 17, 2006 | 01:28 PM
raziel13's Avatar
Default Will header make v-tec louder?
Hello a few weeks ago i dropeed a B16 in to my civic, and YES i do have a short ram intake, however my v-tec is not very loud at all, i mean it works and i can hear it kick in but barely (its way louder on my buddys D16).
Now ofcourse i want to get a header for performance reasons however will it make my v-tec louder at all? Maybe a bit? or a good amount, noticable difference?
Thanks
Old Apr 17, 2006 | 04:27 PM
inh's Avatar
inh
a header shouldnt make your vtec engagement any louder
Old Apr 18, 2006 | 02:07 AM
destroyerx20's Avatar
Default Re: Will header make v-tec louder? (raziel13)
maybe you should try using a p72 ecu (gsr) and getting bigger piping. there are a lot of ways you can make the vtec scream man
Old Apr 19, 2006 | 08:26 AM
civicstar's Avatar
well it should make it louder because of the restriction before, since u have less of a restriction. u can hear it better. when i ran with a stock header, i couldnt hear it. after i put DC headers on my SOHC and an intake, i heard it more. but it wasnt that much louder, but atleast it was noticeable. if u wanted to make it scream. u need better cams
Old Apr 19, 2006 | 10:47 AM
RaceCarRyne's Avatar
Default Re: Will header make v-tec louder? (civicstar)
header exhaust intake alll make vtec louder
Old May 18, 2006 | 06:16 PM
ekx4's Avatar
Default Re: Will header make v-tec louder? (DC2jdmIntegra)
just get some cams.
Old May 18, 2006 | 06:36 PM
b18sihatch's Avatar
bigger exhaust piping, no cat intake, and all that will make vtec louder, but just as long as it works thats all that matters really... just like if you had a quiet blow off valve, as long as the valve is opening and its working is all that really matters
Old May 19, 2006 | 01:51 AM
bsixteen's Avatar
does it really matter how loud it is? as long as it works like it suppose to thats all that should matter lol
Old May 19, 2006 | 07:18 AM
b20vtech's Avatar
just gap the header and u will be satisfy
Old May 19, 2006 | 07:27 AM
trickeng's Avatar
Default Re: Will header make v-tec louder? (b20vtech)
typically the louder your vtec is the worse your tune is.
a properly tuned vtec motor should transition smoothly from non vtec to vtec.
big cams (i.e. stage 3 or bigger) which have a big variations from low lobe to high lobe will make the transition louder but you should still be looking for the smoothest transition possible.
dungsta
May 25, 2005 06:28 AM
civicsidavid
Apr 15, 2004 06:00 PM
ophdehEEzY
Apr 27, 2003 08:01 PM
Fly1865
Jan 28, 2003 07:39 PM
Chuji
May 14, 2002 03:30 PM
