question about obd2 ls swap
Old Apr 17, 2006 | 09:32 AM
error's Avatar
Default question about obd2 ls swap
i already have a b20vtec swap in my 96 hatch. i was thinking of swaping an LS. will i throw a CEL since my harness is currently set up for vtec? or will it not be a problem since ill be using an obd2 ls ecu? im looking for compatability. i need to take the car to a state ref. so i cannot be throwing codes ect... input from those with experiance plz!
Old Apr 18, 2006 | 10:56 AM
error's Avatar
Default Re: question about obd2 ls swap (error)
just trying to get some closure here
Old Apr 18, 2006 | 12:17 PM
suckawillis's Avatar
you will be fine, just some extra plugs hanging around
Old Apr 27, 2006 | 09:14 AM
error's Avatar
Default Re: question about obd2 ls swap (suckawillis)
just need some extra reassurance here...
lets get this straight. im taking out my b20vtec and swapping in a b18a(no vtec). i should not expect any surprises correct? ALSO, i plan on using the b16a throttle body on the b18a manifold, aswell as the alternator from my b20vtec setup. am i still in the green? agin, this is a 98 usdm LS motor.....
Old Apr 27, 2006 | 09:42 AM
alternator, your cool as long as its obd-2. and the throttle body is no problem.
Old Apr 27, 2006 | 04:19 PM
error's Avatar
cool, because im jumping head-first into this thing this weekend....
Old Apr 27, 2006 | 05:49 PM
error's Avatar
another question:
on the b16 throttle body i plan to use there is a hose running into the intake manifold. i would like to use that on my ls mani except there is no connection where the hose should go.
Old Apr 28, 2006 | 08:59 AM
pic? There are a few hoses. you mean the one fron the IACV to the FITV? Or.... ???? need better description
Old Apr 28, 2006 | 12:12 PM
error's Avatar
i hope you can see from the pics what i am talking about. this hose runs from the throttle body right into the intake manifold next to the last runner
Old Apr 28, 2006 | 12:24 PM
error's Avatar
THIS IS A BETTER PIC.....
Old Apr 28, 2006 | 03:21 PM
that is the fitv(fsat idle thermal valve) just tap it into any coolant line. The back end of it goes to the IACV on the back of the manifold.
Old Apr 29, 2006 | 10:32 AM
error's Avatar
lets see if i understand this.
the hose running off of my throttle b. is the FITV. this is not a vacuume hose but a coolant hose. since my mani doesnt have an IACV(there is no place to adapt the hose on the manifold) i just tap a coolant line and i will be fine.
Old Apr 29, 2006 | 01:56 PM
yes, or you can block it off and run no lines, builds better hp, cooler intake charge, but yopu awill have to warm up your car when its cold or it wont idle. Otherwise run both sides of the fitv into coolant hoses
Old Apr 30, 2006 | 08:16 PM
error's Avatar
thanks for the replies!
89civicstd
Jan 21, 2012 09:24 PM
h1ghsp3ed
Jan 5, 2012 08:01 PM
qpzm12
Feb 22, 2011 11:14 PM
carlossolorzano
Aug 29, 2010 09:00 PM
