turbo not spoolin??
Old Apr 16, 2006 | 09:06 PM
kampucheakid's Avatar
Default turbo not spoolin??
i don't know if this is a bad turbo or not but i start up my car and the turbo isn't spooling unless you pull it up to about 5k rpm. just wondering if that's good or not.. and plus i hooked up my boost gauge and it shows only vacuum pressure even when i run my car up to 8k rpm. lmk what you guys think
Old Apr 16, 2006 | 09:11 PM
I Have an STD's Avatar
wrenchin'
Default Re: turbo not spoolin?? (kampucheakid)
lol, u blew off a charge pipe, go check your clamps and thank me later
komat's Avatar
what turbo
also when you pull it to 8k are you going wot?
Old Apr 16, 2006 | 09:13 PM
i checked the charge pipes and everything is koo and vacuum lines are good too. turbo is a t3 KKK turbo from a european car, that's what i was told.
Old Apr 16, 2006 | 09:20 PM
TheShodan's Avatar
Moderator
Default Re: (kampucheakid)
Are you revving to 8K without the car under load? You must be under load for a Honda. Start driving the car and see if positive boost comes in under load.
Old Apr 16, 2006 | 09:47 PM
yee SERIOUS's Avatar
i don't get your problem. lol hey man why don't you IM me on aim. i can probably help you out. i'm from seattle.
AIM: littogpimp
Old Apr 16, 2006 | 10:02 PM
A.E Motoring's Avatar
Default Re: (undercoverdc2)
on a honda u need to be under a load to build boost, your not going to build boost just sitting there and revving
Old Apr 16, 2006 | 10:10 PM
PhantomX's Avatar
Default Re: (SPNFEDEH)
open ur hood play with ur throttle and check the turbine (if u can) and see if its spinning straight....shaft could be bent .... thats wut happend to me...
Modified by PhantomX at 12:59 AM 4/17/2006
Old Apr 17, 2006 | 12:12 AM
when it's under load i'm not sure if it's the bov or the turbo whining, it's like a long whistle..when it's not under any load the turbo spools like at 6k, so i might just get a new manifold, turbo and downpipe setup if i can't find out the problem
Old Apr 17, 2006 | 12:37 AM
RogueWorks's Avatar
you won't build boost without load, drive the car and check the boost that way.
Old Apr 17, 2006 | 12:48 AM
EnzoSpeed's Avatar
Default Re: (RogueWorks)
Even at idle, a little T3 should spin when you blip the gas, right?
Old Apr 17, 2006 | 12:54 AM
i was told that the turbo should spin even at idle. but i have driven it and i feel no gain at all, even my boost gauge was reading between -10 through -20 on vacuum...that's all i get.
Old Apr 17, 2006 | 04:49 AM
Soccerking3000's Avatar
and you checked all your pipes, vaccum lines, bov, wastegate ect.?
Old Apr 17, 2006 | 08:07 AM
why don't you post some info on your setup so we can have a better idea?
what manifold? what turbo?
Old Apr 17, 2006 | 10:33 AM
RogueWorks's Avatar
pop the hood, blip the throttle, it should start to spin. If it doesn't, then there is possibly something wrong with the turbo, or an exhaust leak, or your wastegate is stuck open.
Old Apr 17, 2006 | 09:35 PM
i figured out there was a crack in one of the silicon couplers..haha.. one problem fixed. next thing i saw the turbo was spinning on idle but the shaft is bent..pretty bad, so i'm definitely gonna have to replace the turbo.. any suggestions on what trim specs i should get... really looking for power ranging from 5k-redline lmk what you guys got.
Old Apr 17, 2006 | 11:10 PM
it only reads that much on vacuum at idle, but it's koo now, thanks everybody for the help
allmotor_dm
Jan 24, 2006 06:07 PM
^MikeG
Sep 27, 2003 03:36 AM
slwazgsr
Jun 23, 2003 03:45 AM
InfamousRS
Oct 31, 2001 09:51 AM
shamoo
Sep 11, 2001 05:31 PM
