my car wont start, non-engine problem my key is stuck
Old Apr 16, 2006 | 07:01 PM
96accordlxf22b2's Avatar
I cursed out BauleyCivic and got banned
Default my car wont start, non-engine problem my key is stuck
well i was cutting open bokes at work with my key (the beater so its cool lol) and it got bent, so what do u do when ur key is bent and the car is worth less than the shoe ur wearing? u hammer it back into shape................................ok so i looked at the key and looked like it warped in my mind i say (oh ****) then i say f it try to turn that mother ****** in the ignition key broke, towed car home etc etc. i want to drive this thing not must just want to, is there any alternitive starting methods, btw this is a 1987 200sx
i posted on nissan forums bu they wer like hotwire it!as soon as i said how? they said i dunno ask a theif then i said how the f would i find out if sum 1 is a thief, ya thats the only reply i got
Old Apr 16, 2006 | 07:41 PM
ef0cmacro's Avatar
Default Re: my car wont start, non-engine problem my key is stuck (96accordlxf22b2)
hotwire it!
actually this happened in my civic, i just replaced the ignition switch its pretty damn simple
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
write-up?
edit: for my civic: Remove the black plastic housing that goes around the blinker, wiper stalks, and ignition. You will need a dremel to cut a slice in the top of the left over bolt heads that secure the ignition. (can also use sharp needlenose pliers to turn) Then use a screw driver to remove the bolt. Disconnect all wires and it's out. Order new bolts or reuse the ones you cut and reinstall.
I dont know about your car
Modified by chewbakha at 10:01 PM 4/16/2006
Old Apr 16, 2006 | 07:52 PM
Default Re: my car wont start, non-engine problem my key is stuck (chewbakha)
write-up?
Old Apr 16, 2006 | 08:55 PM
dohcdelsol's Avatar
try to jb weld the key together and then into the ignition. you'll never lose your key, but u would have to find something else to cut open those books.
since its a beater anyways if u dont really care bout it
Old Apr 17, 2006 | 02:16 PM
well its kinda hard to order parts no1 likes the s12 for some reason how can i hotwire it?
easy way? idgaf if i have to hotwire it everytime i drive it as long as it moves, anyways i have the pink slip so if an offcer of the law pulls me over show that and the registration
Old Apr 17, 2006 | 02:26 PM
SiYouLater's Avatar
Try the jb weld trick haha.
Old Apr 17, 2006 | 02:29 PM
EX-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96accordlxf22b2 &raquo;</TD></TR><TR><TD CLASS="quote">well its kinda hard to order parts no1 likes the s12 for some reason how can i hotwire it?
easy way? idgaf if i have to hotwire it everytime i drive it as long as it moves, anyways i have the pink slip so if an offcer of the law pulls me over show that and the registration </TD></TR></TABLE>
Haha, officer of the law!! I've never heard it put that way!
Old Apr 17, 2006 | 09:21 PM
Default Re: my car wont start, non-engine problem my key is stuck (EX-T)
hows pork loin of the law? that i owe 800 dollars for not having a ******* sticker on my car
Old Apr 17, 2006 | 09:35 PM
SiYouLater's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96accordlxf22b2 &raquo;</TD></TR><TR><TD CLASS="quote">hows pork loin of the law? that i owe 800 dollars for not having a ******* sticker on my car </TD></TR></TABLE>
The registration sticker?
Old Apr 18, 2006 | 06:23 PM
Default Re: my car wont start, non-engine problem my key is stuck (99FBPSi)
ya
Old Apr 18, 2006 | 06:46 PM
99EeeKay's Avatar
a lock smoth should be able to pull the key put for around 10 dollars... and then have that lock smoth make you a copy of that key for 1.50. and bam,your set
EF_LSVtec
10
Jan 27, 2017 04:36 PM
96integrals1505
Aug 27, 2006 03:38 PM
theif101
11
Dec 4, 2005 12:16 AM
liljohnson
Aug 12, 2004 11:48 PM
Briman2021
Feb 3, 2004 12:03 PM
