Engine Swap Help
Old Apr 16, 2006 | 05:46 PM
supersonics1996's Avatar
Default Engine Swap Help
I'm buying a b16 bloack and it comes with crank,pistons,rods,oil pump,oil pan, b16 cams, and i think its either gsr or b16 cams. Is that a complete block? And other than a head and an ecu what else would I need to swap this into a civic dx? Any help would be great. thanx
Old Apr 16, 2006 | 05:47 PM
Lewy. Dee Ayy's Avatar
Default Re: Engine Swap Help (supersonics1996)
well..all depends on the car its going into..but im assuming its out of a car with a d series..so ul need a b series trans..and axles..and motor mounts..and prob other things ppl will tell u..
Old Apr 16, 2006 | 05:50 PM
The Clash's Avatar
Besides a head you need all the accessories - alternator, distributor, intake manifold, fuel rail and injectors, various sensors, etc. Then you will need a B series hydro tranny, axles, shift linkage and proper OEM mounts to get it bolted in. For all of these parts (in most cases), none of your D series parts will work.
Old Apr 16, 2006 | 05:51 PM
fmrprojects's Avatar
Default Re: Engine Swap Help (WhiteOut)
thats a alot u will need. its better just to pick up a complete swap. if you start getting all the parts its gonna cost you as much as buying a whole swap
Old Apr 17, 2006 | 12:32 PM
Thanx for the help. it looks like ive got a lot of work to do.
Anthony Lorenz
Sep 14, 2019 09:31 AM
Anthony Lorenz
Engine Machining & Assembly
13
Mar 11, 2019 03:33 AM
95EG2
15
Dec 2, 2009 01:34 PM
hondajav06
10
Jun 16, 2006 06:23 PM
awalk2005
Jul 14, 2003 05:54 AM
