Need help with engine swap!
i have a 99 civic ex with a D16 engine and i want to swap it with a B16 or B18. what will i need to modify? will my transmission from the D16 work with a B16 or B18?
Re: Need help with engine swap! (awalk2005)
No it will not work: D series trans are not compatible wit B series motors
You will need complete swap: Engine, Trans, Shift linkage, Axles, halfshaft, ecu, and various mounts from the 99-00 SI.
Re: Need help with engine swap! (civicrtype)
like the guy above said no your d series tranny is not compatible with a b series motor.just type in b16 or b18 in the search engine and you will a lot of helpful threads that will tell you all the parts you need.good luck man!
Re: Need help with engine swap! (all-mota)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mota »</TD></TR><TR><TD CLASS="quote">just type in b16 or b18 in the search engine and you will a lot of helpful threads that will tell you all the parts you need.good luck man! </TD></TR></TABLE> Good nOOb...*pats head*...I love when we get guys like you in here...that have a head on their shoulders.
Guest
Posts: n/a
Re: Need help with engine swap! (2kB16B)
http://www.hondaswap.com
http://www.hybridgarage.com/
these links should help you
I think you should swap in an obdII b18b. I know somebody that has an ecu for sale.
