*APEXI AVCR NOT WORKING*
installed my apexi avcr, and the unit turns on but it wont controll boost. me and jeff at evans tunning both screwed with it a little still nothing. when u set boost it wont hold it it will go all over the place and the boost readings are off. any ideas whats going on will help thanks
did you by the unit new or used. I had the same problem with on turn out the unit itself was bad. swapped a new one and it worked with out problem..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtechb »</TD></TR><TR><TD CLASS="quote">sounds like the lines from the solenoid to the waste gate are hooked up improperly</TD></TR></TABLE>
no they arent
no they arent
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MONSTERZC »</TD></TR><TR><TD CLASS="quote">did you by the unit new or used. I had the same problem with on turn out the unit itself was bad. swapped a new one and it worked with out problem..</TD></TR></TABLE>
what unit? the controller,soleniod, or that boost reader
f22bandit
Mar 11, 2005 07:55 AM
