help civic problems
hi from germany,I have speed fluctuations wen my car motor is warm ???
from 900 to 300 rmp.. up and down like ping pong ball
i have change..
spark plugs ., water coolly, battery, eavc iavc, butterfly valve, map sensor, ECU,temp sensor,gasoline pumps,filter,seal.
i have found no negative pressure ,vakum???no no cable break(wireles)..
compression is ok..
help.
i have change..
compression is ok..
help.
all in red circle i have changed and testing???
but still rmp fluctuations..???
look pic..
http://rapidshare.de/files/18161065/tttt.JPG.html
http://666kb.com/i/11daqn8y67dhd.jpg
look pic..
Check your programming in your computer. Turbo cars, especially if they are running heavy injectors, have a hard time idling if they are getting to much fuel. Most people fail to realise at igle the stock setting is too much on upgraded injectors and it needs to be turned down. You might be flooding it.
ecu is now low programming for rc injectores..
wen i turn 1100 rmp on screws tps, i have not speed fluctuations and motor is ok...
wen i use under 1000 rmp tps-screws ,cames again speed fluctuations 1000-700 rmp..???
ground kable error???ore low battery energy???battery test 14,3vollt alright
Bigrome34
12
Jul 27, 2010 01:01 PM
Turbozcivic96
Jun 14, 2010 04:57 AM
AP2S2K
Jun 12, 2007 05:24 PM
kowekiller
Aug 4, 2006 11:08 AM
