Need Help Installing JDM Foglights
Old Apr 16, 2006 | 03:11 AM
Mr Synister's Avatar
Default Need Help Installing JDM Foglights
Ok I just got some JDM foglights with brackets and wiring harness. Now my question is how do I go about wiring the fogs ? What do I have to connect what to what. I know two connections go to the fogs but what about the rest ? Anyone who knows let me know. If someone gets lost with what I'm saying I'll take pics of the wiring harness later so someone can help me out, but if you know what I'm talking about the help would be appreciated.
Old Apr 16, 2006 | 02:19 PM
Default Re: Need Help Installing JDM Foglights (Mr Synister)
Come on someone has to know.
Old Apr 17, 2006 | 07:00 PM
UP for some info....
Old Apr 17, 2006 | 07:24 PM
Corran's Avatar
Well, if it's lights, do you want it to turn on when you turn on the headlights, or do you want them seperate? If you want it to turn on with the headlights, run the B+ (or positive) wire through the firewall to the fuse box under the dash. The back side of the panel covering the fuse box lays out what fuses are for what. pull the fuse for a headlight, or something that comes on with your lights, wrap the bare end of the + wire to one of the legs of the fuse and stick it back in. Ground the other wire to the chassis, and the fog lights should come on with the headlights
Old Apr 17, 2006 | 07:27 PM
Corran's Avatar
for seaperate, run the B+ to the one post of a switch. take new wire from the other post to the fuse for the clock/sterio to be able to turn it on at any time. dont forget to ground the other wire too. Red = +
Black = -
Old Apr 18, 2006 | 07:30 AM
Wes V's Avatar
Default Re: (Corran)
Contact Eric (fourthgenhatchb17) and ask him if you are looking for a "factory" hook-up!
Wes
g0tgot
Jul 4, 2007 05:03 PM
USDMSiR
Jan 9, 2007 05:28 PM
tjd92accord
Feb 4, 2006 08:52 PM
mooook
Oct 23, 2004 08:26 AM
paulzy
Feb 12, 2003 06:22 PM
