95 civic help ! Electrical
I need either a schematic or someones infinite wisdom.
I want to install a relay to shut off my daughters headlights, when she has turned off the key.
Or a chime that will be on when headlights are on, and keys are off.
Your help would be greatly appreciated.
Re: 95 civic help ! Electrical (tjd92accord)
when you get a wire diagram you can go to your fuse box and switch the posative wire from the back of box for one that has no power while key is off. such as the radio fuse. you could cut the right power wire for the headlights and solder it to the radio power wire just make sure its after the fuse and the same amp reading on fuse also make sure its after the fuse so you dont go straite to the lights without going through a fuse or fire can happen..
ps. not responsible for burned up car read wiring diagrams and understand or take it to a professinol
ok i saw your other thread, and i found a few diagrams on a few other threads. what year is her car?
should you get impatient in waiting for my response, many results may be found by searching for 'fuse box' in this specific forum, '92-00 civic/del sol'
TooManyHobbies
09-22-2014 05:12 PM
EFresh
10-12-2007 08:12 PM
