help just installed peakboost turbo kit and car wont start
Old Apr 15, 2006 | 08:15 PM
hatchonarun's Avatar
Default help just installed peakboost turbo kit and car wont start
i just intalled my peakboost kit on my gsr block with b16 head okay first ill let you know my setup - gsr block, b16 head, aebs intake manifold, bbk throttle body, peakboost kit t3t4oe 60 ar, 550 rc injectors saturated, walbro 255 fuel pump, p72 ecu with obd1 jumper harness stock boost basemap chrome... i started my project around 2-3 weeks ago i finally finished it tonight due to parts anyways everything is bolted on except for my o2 sensor (both unplugged) cuz my downpipe doesnt have an o2 bung i change the spark plugs to ngk-8 and tonight i started crankin it up first without the plug wires so i can get oil on my turbo then i plugged it up but car wont start it just keep on cranking if anyone knows why please feel free to voice yourself out i would really appreciate it... car was healthy and started right away when it was n/a....
Old Apr 16, 2006 | 01:59 AM
charlee's Avatar
Default Re: help just installed peakboost turbo kit and car wont start (hatchonarun)
do all the usual and check if you have spark in every wire.when i installed a turbo for a friends project car. during the proces of hooking up the BOV wiring. i accidently disconected a plug on the distribuitor.i cant remember witch one.i supposed i hit it with my elbow or sumtin.also make sure that your turbo is spining .if it smells like a flooded angine (a unburnt gasoline smell on the engine)
then is most likely an electrical problem since you know your pump is pumping good ect.i hope i was of any help.
Old Apr 16, 2006 | 06:13 AM
Default Re: help just installed peakboost turbo kit and car wont start (charlee ricer)
k i will do that, i did kinda check if there is sparks on the wires and it seems like it doesnt so i guess thats one of the problems but i never touch the distributor though nor unplugged any wires and i did double check all the wires but i will check it again later... thanks anyways all help would be greatly appreciated
dsturch1
12
Oct 26, 2010 09:13 AM
ticaaal70
Aug 21, 2010 08:52 PM
Luward
Apr 19, 2008 07:31 PM
hatchonarun
Apr 18, 2006 05:47 AM
OKSolSi
May 14, 2002 04:36 PM
