02 Wiring Color - Yellow From Harness Right?
Old Apr 15, 2006 | 07:29 PM
PINKS's Avatar
I want a CRX tattoed on my butt
Default 02 Wiring Color - Yellow From Harness Right?
Just swapped motors and am a little confused on the wiring that goes on ontop of the tranny
the only wire I have that I can see that is unhooked is a yellow wire that comes out of the harness above the tranny
The only connection I have is my 02 sensor, which is a black wire,
Do these 2 go together? I have the extend the yellow (if it is there right wire) to make it to the back of my downpipe
Im hoping it is
Old Apr 15, 2006 | 10:08 PM
Rywire's Avatar
Default Re: 02 Wiring Color - Yellow From Harness Right? (TurblowEF)
yellow? Im thinking thats a backup switch wire. white is the c16 o2 signal (sometimes has a black shielding).
Old Apr 16, 2006 | 03:27 AM
PINKS's Avatar
Default Re: 02 Wiring Color - Yellow From Harness Right? (droppedcrxsi)
Well I had a bunch of butt connectors there just above my tranny, they all went together mint and I only had a yellow left with no connector
The car is a canadian 88 crx si
Old Apr 16, 2006 | 08:14 AM
DieMaster's Avatar
Needs to be About 20% Cooler
was your car an auto? i got the same yellow wire and it goes to the toque converter lockup solenoid on the trany.
Old Apr 16, 2006 | 12:50 PM
PINKS's Avatar
Default Re: 02 Wiring Color - Yellow From Harness Right? (DieMaster)
No its manual, I check the harness today, the wire is definetely not yellow, its like a creme colour, cleaned it and it stayed the same, I figure its the right wire since there are only yellow and green coming out of that loom and its just sunfaded...?
Another question, this wire no longer had the plastic connector on it so I just cut the connector off of the other wire and solderred them together, this is a 1 wire 02 so thats no problem right?
Thanks
Old Apr 17, 2006 | 05:19 PM
PINKS's Avatar
Old Apr 18, 2006 | 02:49 AM
PINKS's Avatar
bump
Old Apr 19, 2006 | 07:55 PM
PINKS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurblowEF &raquo;</TD></TR><TR><TD CLASS="quote">No its manual, I check the harness today, the wire is definetely not yellow, its like a creme colour, cleaned it and it stayed the same, I figure its the right wire since there are only yellow and green coming out of that loom and its just sunfaded...?
Thanks</TD></TR></TABLE>
Old Apr 20, 2006 | 02:26 AM
PINKS's Avatar
Old Apr 20, 2006 | 01:19 PM
PINKS's Avatar
Old Apr 20, 2006 | 02:05 PM
Rywire's Avatar
Ya, that sounds like o2, and yo can solder a new connector on
Old Apr 20, 2006 | 05:15 PM
PINKS's Avatar
but i dont need it right?
Old Apr 20, 2006 | 11:15 PM
Rywire's Avatar
o2 signal?? yes you do
Old Apr 21, 2006 | 02:28 AM
PINKS's Avatar
no, the little plastic big bulky connector
ineedavtec
Jan 7, 2012 12:31 AM
uncledan
Jul 8, 2009 04:57 PM
JDMlyfestyle
19
Feb 4, 2005 07:51 PM
king tuck
Mar 29, 2004 06:42 PM
FUP23
Aug 8, 2002 04:54 PM
