what gasted do i need for this leak?
Old Apr 15, 2006 | 03:25 PM
Walterronny's Avatar
Default what gasket do i need for this leak?
Old Apr 15, 2006 | 03:41 PM
Combustion Contraption's Avatar
New OEM / Billet cam seal.
Old Apr 15, 2006 | 10:12 PM
egsleepercivic's Avatar
most likely cam seal, you may want to go ahead and replace the dizzy o-ring while you on that side of the engine
Old Apr 16, 2006 | 03:56 PM
JDMtype Eg6's Avatar
get an aftermarket aluminum cam seal. Oem cam seals tend to harden and breakdown after a while, causing the leak you have now.
Old Apr 16, 2006 | 05:16 PM
confusatron's Avatar
Default Re: what gasket do i need for this leak? (Walterronny)
Ditto. Get an aluminum aftermarket cam seal. I got mine from STR, but they're all pretty much the same shape and quality. I had already bought a cheapass plastic generic OEM one to replace mine, but the quality on the aftermarket one blows the OEM one away, so I returned the OEM one to the Honda dealer and installed the aftermarket one. It's so much better, that paying the extra ten or fifteen bucks is totally worth it.
http://www.racingworks.com/str_cam_plug_seal.htm
SLOENUF
Mar 12, 2011 06:06 AM
HyperFlow
Oct 9, 2010 07:59 PM
nonvtec92
Nov 1, 2009 01:28 PM
DC-2guy
May 5, 2009 06:36 PM
Twigster311
May 22, 2003 06:43 AM
