Washed the engine bay... think I missed up?
I've done this before on various other Hondas and I covered the alternator, intake and distributor. I let the car dry thoroughly and now when I start it I have a ROUGH put-put-put kind of idle and my CEL went on.. WTF did I do!
I just noticed after washing that the AEBS intake manifold I have on my car, it has 2 holes drilled into it that I can see through the bottom of the engine bay... did I hydrolock my engine?
I tried letting the car idle to let the engine get up to operating temp, but all I get is a flashing CEL, and my exhaust sounds like a diesel car. Any info on this?
let it run a little to make it warm up and it will take a bit of time like 15 minutes for it to go away. It happen to a buddy of mine just be acareful next time.
Dave
Dave
i bet looking up the check engine code you are getting would tell you what the problem is, and i bet it would tell you that you have a missfire in one cylinder, causing a weird idle.
and there might be some water in that spark plug tube...
Thats really strange because I have the spark plug cover on and I didn't spray from that direction. As far as I know its bone dry underneath it.
I guess I'll let it idle for a good while and pray it fixes itself. Otherwse I am SCREWED.
Thanks guys.
Thanks guys.
its misfiring a little, but not throwing any codes.. I'm giving it 20 mins to try and smooth itself out/dry.
No kidding.... I was shitting bricks. I thought it was hydrolocked and I had to buy anotehr engine or do a rebuild.
it's common to get water into the distributor when washing the engine. if that's the case just take off the cap and blow in it with an air hose..
b20bFourDoorCivicLX
Aug 18, 2013 02:29 PM
