Problems with Eagle H-Beams in a 93 z6???
Anyone have clearance problems with the Eagle Hbeams in a z6? I got my motor back from the machine shop and went to install it.. I put piston 1-4 in and then tried to turn the crankshaft and it binds... It looks like the webbing and rod bolt is hitting the cylinder walls?
Has anyone else had this problem? What did you do to alleviate the problem? How much did you have to clearance the cylinder walls? Did you have any problems getting too close to the coolant passage?
Should I just get different rods? I can't believe they don't fit...
